Fuel consumption emergency aid ...
08.05.2020 16:24 # 1
caan_caan
Hello friends, I have 97 models 1.6 306 vehicles, my question is 186 km with 80 TL, my gasoline is over, I bought 40 TL & nbsp; I made 64 kms of it, my gasoline was reset again, this time I bought 75 TL of fuel. ..
Thank you very much for your help ...
08.05.2020 16:24 # 2
Ucyuzalti
First of all, are these values in and out of town? If you are in the city, your first value is 80 TL, and the fuel you buy is 98 gffees. How did you take this measurement?
08.05.2020 16:24 # 3
caan_caan
The values I wrote are in-city values, I put 40 TL of fuel in the empty tank, and I used the car in the city until the tank was empty. I felt that there was an abnormality, I wonder if the age of the vehicle related to spraying is in the middle or it burns 306s last time, I bought 75 TL of fuel, of course. to guide me about ...
08.05.2020 16:24 # 4
Ucyuzalti
I did not measure it, so I didn't use the tank until it was empty. If you say why I was afraid that it would be a bit of a pump, "Smile" If your journey is a bit like going with a cold engine as soon as it does not fall below 40k, your journey will increase further, 306 is an economical vehicle. But to list the factors that add fuel:
Dirty air filter increases fuel
burst exhaust, abart exhaust increases fuel
worn spark plug spark plug cables increase fuel
tightening brakes increases fuel
vehicle thermostat defective the vehicle does not heat up fuel
low tire air
driving style hard to use directly increases fuel satin
this and other factors affect your fuel ie maintenance fuel & nbsp; directly related
08.05.2020 16:24 # 5
caan_caan
so how do i know if i burn 40 kurus
08.05.2020 16:24 # 6
Ucyuzalti
The healthiest way to measure fuel: You complete your tank, you make a certain km with your normal usage style, then go to the same station and fill your tank with the same amount of liter or something. Then dielim bought 12 liters of gasoline, you will find what you burned the way you did. = "Big smile" /> "LOL"
