Fuel consumption calculator
08.05.2020 15:40 # 1
deamod
How can we calculate how much gasoline it burns in the city outside the city as it is more or less obvious in the title?
08.05.2020 15:40 # 2
Fill the tank until you drop a gun from a station you know and do not force it. Then use the timers after resetting the counters and go to the same gun of the same station, complete it again. Make a note of how much fuel you take, and then divide that value by the kilometer you traveled. The more kilometers you have made, the more precise you can calculate. 100km. + Recommended. Koliva 2011-06-21 08:41:05
08.05.2020 15:40 # 3
metin
+1
08.05.2020 15:40 # 4
GokhaN
[QUOTE = deamod] How can we calculate how much gas is burned in the city outside the city as it is more or less obvious in the title? [/ QUOTE]
You can never calculate exact values precisely because we drive in constantly variable conditions. If you are getting on your car originally, I do not estimate that it will burn less than 10 liters in city traffic due to 11 years old vehicle and it will burn less than 6-7 liters outside the city.
Take a line on the fuel gauge in line, take 50 TL of fuel and reset the vehicle's km indicator. Look when it comes to the same line. If you divide 50 by km, you will see the fuel it burns, but not nearly in full.
08.05.2020 15:40 # 5
Engin Tepe
Partner with 195 TL diesel and 780 km. In-house (I always use sports)
08.05.2020 15:40 # 6
friends, I bought 237 liters of gas for 307 to 100 tl. I made 340 km of the city with this gasoline, how do you think ....
08.05.2020 15:40 # 7
Not bad according to the conditions ...
08.05.2020 15:40 # 8
orhanax
[QUOTE = koliva] Fill the tank until you drop a gun from a station you know and don't force it. Then use the timers after resetting the counters and go to the same gun of the same station, complete it again. Make a note of how much fuel you take, and then divide that value by the kilometer you traveled. The more kilometers you have made, the more precise you can calculate. 100km. + Recommended. [/ QUOTE]
+1
Even the best way is to do this test in a thousand km process. You will get more realistic results.
08.05.2020 15:40 # 9
I had no money to go for 100 km, but I calculated that he burned 2.1 lt of gasoline at 50 km.
08.05.2020 15:40 # 10
Long Beach
[QUOTE = ersintepe] I had no money to go 100 km, but I calculated that it burns 2.1 lt of gasoline at 50 km. [/ QUOTE]
4.2 liters per 100km according to your account, no possibility
The best km / lt account is the friend of the publication at the beginning, this is the most correct method. Measurements made when aligning the gas gauge are not correct. For example, put gasoline indicator 2lt above 1/4 into the tank, the indicator will not play
08.05.2020 15:40 # 11
I thought it would give a definite result.
08.05.2020 15:40 # 12
onur3434
I filled it up to its cover: D 52 lt 197 TL 600 Km I went not in sports every day 15 km of city road traffic is very low 197 TL / 600Km = 328 Kr Inner city Burning car: S
