Fuel consumption
08.05.2020 15:40 # 1
deamod
Friends when I bought my car, the open air filter is on it, it seems like the car is burning a little bit. If I bought the original air filter from the dispatchers, the fuel consumption will be low.
08.05.2020 15:40 # 2
if you use cycles, it burns less than the original air filter
08.05.2020 15:40 # 3
deamod
If you use [QUOTE = pugti] speed it burns less than the original air filter [/ QUOTE]
Hmm alone, after enjoying 3000 in his voice: D
What happens if we use unbound :)
08.05.2020 15:40 # 4
metin
If you say that you will hear your voice, your fuel will increase. but if you use it calmly as if the normal filter is installed, it may fall even more than the original filter.
08.05.2020 15:40 # 5
GokhaN
I used 2 different filters in my old 106. Jsv, Raid Hp. I have not seen the fuel drop even in calm use in both of them, and the fuel increases between 20-30 kurus. I do not recommend anything to get other sound from the last muffler. Don't forget to keep your original muffler. After your head is swollen and tightened after a while, you will wear the original.
