fuel consumption? 1.4 petrol 207
08.05.2020 19:01 # 1
Cry SA
Friends my vehicle 2008 model 1,4 trendy 207
It's been 2.5 months since. I am using the vehicle in Istanbul and it burns 50 cents exactly?
Cry my stove is extinguished Cry
What can I do to reduce the fuel a little and my car is at 97,000 kilometers. What maintenance and changes do I save?
08.05.2020 19:01 # 2
monalos
how much is there for maintenance
08.05.2020 19:01 # 3
[QUOTE = monalos] how much maintenance? [/ QUOTE]
my vehicle is at 97.000 km ..
I guess they have maintenance in 100.000 ???
08.05.2020 19:01 # 4
monalos
There is an oil card in your hand for 10 thousand, you have an oil card, there is a change in the writer.
08.05.2020 19:01 # 5
[QUOTE = monalos] There is an oil card in your hands for 10 thousand, there is a change in the number of writers, for example, they have maintained my car in 138 thousand, I was renewed every day in 148 thousand days, now I will get up to 158 thousand, and if you look at the maintenance paper, you may have a problem in the filters. there is, it affects the fuel maintenance [/ QUOTE] yes I'm sick. it says 92.000 on the oil card, both the oil and the filter were changed.
But when do you think I should maintain other filters such as fuel filters? I don't understand these works. 50 cents is not too much do you think Dead
08.05.2020 19:01 # 6
monalos
If your vehicle is in maintenance, I will investigate and tell you why it burns so much
In my opinion, do you travel for a lot of 1.4 engines daily, for example, how many times do you press the ignition per day, do you stop? how many thousand times you use it important in these
fuel situation factory data is unlikely to burn such a vehicle below factory data
if we calculate the water data;
Considering that the price of petrol lt is 4.05 TL, it is 8 liters in the city, you will go 100km with 8lt = 32.4 TL.
It is necessary to burn 0.32 kurus per km, of course, according to statistics, it is normal to burn between 0.30 and 0.35.
Fuel consumption in the city 8.5 (7.9) l / 100 km Bu arabanın bilgilerini düzenle
Extra-urban fuel consumption 5.2 (5.2) L / 100 km Bu arabanın bilgilerini düzenle
Average fuel consumption 6.4 (6.2) L / 100 km
monalos 2015-01-19 21:46:07
08.05.2020 19:01 # 7
[QUOTE = monalos] fuel situation factory data is unlikely to burn such a vehicle below factory data
I do not want to have lpg installed on the vehicle ..
but I have never guessed that it will burn so much. stop, stop, do you spend a lot of fuel ?? The foot clutches, the clutch brakes, it swore. -I did not go 2-3 km without stopping once, should I waste the car in red lights ?? Will it affect consumption
08.05.2020 19:01 # 8
monalos
when you stop at the red lights, shifting the gear will fix the life of the clutch lining rather than fuel saving.
I have 206 I got 1.4 when I bought it, I was doing 100 km to 30 TL
I don't want to install a tube.
Can you tell me how you calculate fuel consumption, can there be any error? fulle tank 100 km and then look at the fulle again at 100 km.
monalos 2015-01-19 21:51:52
08.05.2020 19:01 # 9
I do not use the tool very fast.
I use it in 2,500-3000 rpm. When I hit 3,000, I change gear immediately.
I'm not stepping on the car ..
I put 50 liters when the car's fuel light turned red. I wrote the mileage. After 100 km, it burned red again .. even after 97 km ... am I calculating wrong ?? LOLLOLLOLLOL
08.05.2020 19:01 # 10
monalos
You can follow the tank after a full fulle. When it is 100 km, let's look at the full fulle.
08.05.2020 19:01 # 11
let's see my fullest, hopefully ..
I'll try to bidet .. how many kilometers will go after the fuel light turns red Clap
08.05.2020 19:01 # 12
monalos
It says 50 km in the operating manual, but after I burn, I go 60-70, I did not calculate, but my heat never goes out: D student island: D the operator's cons would not go up like spending: D I buy gasoline goes out, hop back on: I go 150 km to 50 TL 50 tl light is going out, 80 light or something is gone and then the back light is on
08.05.2020 19:01 # 13
[QUOTE = monalos] it says 50 km in the user manual, but after I get burned, I go 60-70, I did not calculate, though, my heat never goes out: D student island: D the operator's cons would not go up like spending: D I buy gasoline goes out, hop back burns: D 50 I'm going 150 km to TL, 50 TL light goes on, 80 light goes on and then back light [/ QUOTE] Big smileBig smileBig smile
What would I want from ALLAH if my vehicle burns like yours ...
I can't get on, I feel so much right now
08.05.2020 19:01 # 14
monalos
Let's make a definitive diagnosis and we'll see what we need to do after that, don't let the lions feel sorry :)
08.05.2020 19:01 # 15
[QUOTE = monalos] Let's make a definite diagnosis after that we will see what we need to do, let the lions do not be sad :), I saw a lion I can not stand, I am excited with my lion :) [/ QUOTE] ClapClapClapClapClap Thank you for your answers .... good evening
08.05.2020 19:01 # 16
monalos
Good evening
08.05.2020 19:01 # 17
KILIC
I think you are doing a lot of stop in normal traffic like Istanbul.
08.05.2020 19:01 # 18
sezar206
Stand on gasoline, get 50 cents, what more do you want? P. On gasoline You are waiting for 30 boxes inside :) No handling is perfectly normal fuel.
08.05.2020 19:01 # 19
[QUOTE = fatihpekgoz] Stop at gas, get up to 50 cents, what more do you want? P. On gasoline You are waiting for 30 boxes inside :) No handling is perfectly normal fuel. [/ QUOTE] Please do not misunderstand, but whoever I ask says 30/35/40 kurus. I do not think there is a usage error or a problem caused by me. I am thinking of putting my car into service so I asked. What kind of care should I have? I am 21 years old. my first car has some ignorance
08.05.2020 19:01 # 20
Barut
My first manual car was 206 and it burned 65 cents 3 years ago. Because we are novice. Now my gasoline lt is around 4.10. If it burns 100 km or 10 liters, it will make 40 cents per km.
Page : / 4
