Fuel Circuit Breaker Disabled |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper | |
| 08.05.2020 20:18 | # 1 |
| 08.05.2020 20:18 | # 2 |
did you get the last diesel you got from different place
| 08.05.2020 20:18 | # 3 |
Yeah
| 08.05.2020 20:18 | # 4 |
was it from him? so what should i do?
| 08.05.2020 20:18 | # 5 |
I think you can finish the diesel in the tank, buy it from a good place you know, use it again, show it to the master after using it a little more, but change it to the diesel filter in the first maintenance
| 08.05.2020 20:18 | # 6 |
Thank you very much, Mr. Gökhan. I will try what you say.
| 08.05.2020 20:18 | # 7 |
I did what you said and the warning light did not come on again. In the first maintenance, I will change the diesel filter anyway. Thank you again for your suggestions, Mr. Gökhan.
| 08.05.2020 20:18 | # 8 |
The same problem started again, unfortunately. I was still on the road today.When the traffic was clogged and I was waiting for a long time, check the gearbox with the sound of the block and wrote the car stopped.It did not work for about half an hour. hours later, the vehicle worked and continued on the road. Before I show it to a master, I ask for advice and information.
| 08.05.2020 20:18 | # 9 |
looking at the brother, these peugeots are problematic and there are always similar problems.
| 08.05.2020 20:18 | # 10 |
Thank you. Get well too. I do not know all of them are problematic, but there is a bit of luck. Today I went to a gearbox. Let me see it properly. I said I'll come after me. I know.
| 08.05.2020 20:18 | # 11 |
It's been a long time. We could not write an answer about the situation. We solved the problem. Problem; the pressure was about to end. At 120 thousand km, the pressure was starting to end the pad. it also became a problem with the gear shifts when it warms up and stops. It has been about a month since the print changed the pad and I had no trouble.
| 08.05.2020 20:18 | # 12 |
Fuel breaker disabled warning was due to the parking lamp. I had turned on the parking lamps before the vehicle started. Check the parking lamps warning. Immediately behind it, the fuel cutter wrote off the screen. I went to a good electrician and replaced the bulb of one of the parking lamps. After that, he did not warn about the fuel breaker.
| 08.05.2020 20:18 | # 13 |
I'm having the same problem right now. Fuel cutter says disabled, but the vehicle is running. This warning started when I last completed the warehouse. Could you learn the location of the sensor?
| 08.05.2020 20:18 | # 14 |
[QUOTE = daydream] It's been a long time. We could not write an answer about the situation. We solved the problem. Problem; the pressure was about to end. At 120 thousand km, the pressure was starting to end the pad. it also became a problem with the gear shifts when it warms up and stops. It has been about a month since the print changed the pad and I had no trouble. [/ QUOTE] I have the same problem with my brother. Where did you change the print ax? Is he a master in Ankara? If I go too. How is the vehicle now? Does it work properly? Thanks.
| 21.12.2025 14:43 | # 15 |
I suddenly saw a fuel cut-off deactivated warning on the screen. The vehicle was parked. https://static.cloudflareinsights.com/beacon.min.js/vcd15cbe7772f49c399c6a5babf22c1241717689176015" integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28oN72PdrCzSjY4U6VaAw1EQ==" data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCacheStatus":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">I couldn't get it to work no matter what I did. I fiddled with the turn signal lever, moving it left and right, but it didn't work. The next day I did some research. I downloaded the fuse box template for the interior and exterior of the vehicle. The same situation applies to 2008 Fiorino, Bipper, and Nemo. The vehicle's fuse holder has expanded. One leg doesn't stay in place properly due to the temperature difference. I replaced it with a new fuse. I even used pliers to remove the leg. I bent it and secured it perfectly into the socket. As a result, the trouble is over.
| 21.12.2025 14:46 | # 16 |
The fuse box template and the fuse I replaced weren't very expensive. https://static.cloudflareinsights.com/beacon.min.js/vcd15cbe7772f49c399c6a5babf22c1241717689176015" integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28oN72PdrCzSjY4U6VaAw1EQ==" data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCacheStatus":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">It's very simple to remove and install. It can be done with the help of pliers or needle-nose pliers. I will add a picture. I'm happy if it helps.
