fuel and itching
08.05.2020 17:54 # 1
onurtez
Friends, not many, I joined you before the feast. My previous vehicle was 2011 1.5 80 hp hundai getz. My current vehicle is 2003 307 1.6 rx automatic
I don't know what the users are thinking, but today my friend's vehicle used the 2006 getz tool to give it a nostalgia :) but I said that there is a lot of difference or this car is really a series. I went down to 307, I bought a manual e tool, there was an itch. When buying the vehicle, the biker said that someone exhausted the exhaust is clogged, then it hurts, I said it was broken, I changed the exhaust to 350, I couldn't see the difference, and the vehicle was relaxed. Plus, I went to the bay in the old times and I went to the bay once, I would go through the routine routine, I would spend 300 tl of fuel during the holiday, I would have gas, I accelerated a little more, I had a wasteer, I even had a system, I got it, I got it, I had a system, I got a wrench, it was more of a car, my hair was more flammable. I am full of the tank for 105 TL. I have 4 lights. 3 of them are gone. The second light is burning in between. I think it will start over 200 km in average :(
I guess there is a problem, what is it? What is it? If we say that the performance is normal, it will burn more than x5 if I do: S x5 does not burn as much as I want.
08.05.2020 17:54 # 2
error
your throat butterfly can be "sucked in a place where it can adapt" to absorb or blockage in exhaust.
08.05.2020 17:54 # 3
qqyyxx
If they wanted to mean a convertible from the obstruction in the exhaust, it is unlikely that there was no such thing as an obstruction in the vehicle's exhaust system. You also did not pay much attention to the lights in the lpg's key. consider it there. don't compare with getz also getz light car also has a motor with torque compared to diesel chassis but you can't go with it as you go with 307. Since your vehicle is automatic, its fuel will be higher as it is.
08.05.2020 17:54 # 4
onurtez
Dda is not safe for the masters, take a tour, come and go, no matter where I say, it will change in the x part, we will not notice the difference.
08.05.2020 17:54 # 5
qqyyxx
If you do not know the job, you must deal with the conscience of the master. Conscience seems to be out of the world these days.
08.05.2020 17:54 # 6
error
Well, dude, if you say that it is opening later, the first problem comes to mind here at lower ages,
I do not know if egr cancellation is healthy in automatic vehicles that might be a problem in the egr system, but we should note the egr aside.
then there is a possibility that the catalytic converter is blocked, this filter has an option such as floor cleaning and cancellation with a price over 1000 lira.
The possibility of accumulation of harmful soot accumulation in the motor is the carbon clean option here.
There was no idea that there was a problem with the gearbox.
In other words, it is in your interest to find a master who knows the competent peugeot, but you have an alternative in Istanbul, but it is hard to find experienced qualified masters outside the city.
