fuel
08.05.2020 17:10 # 1
farabi
friends, there is a 2006 model x design, and I am burning gasoline 1.4 cent 50 cents in other words, I go 200 km with 100 TL gasoline. I got the new head in the car, nothing changed
is this normal or is it a pronblem? I'm living in manisa by the way
& nbsp;
08.05.2020 17:10 # 2
farabi
I think how much he should burn the overestimate or why. If you burn 100 km 11 liters, please write with other ideas.
08.05.2020 17:10 # 3
Serkan
Teacher, if you are using in short distances, it is normal.
08.05.2020 17:10 # 4
osman_bora
the cover of the air filter may not be seated properly, check the diesel filter, get the fuel from the shell, get power gtl diesel, load the vehicle without heating the engine, and if you did something about the electrical component in your vehicle, connect your computer to the computer, delete the errors, replace the parts for uninhibited errors I think there will be no problem
08.05.2020 17:10 # 5
Serkan
[QUOTE = osman_bora] the cover of the air filter may not be seated properly, check the diesel filter, get the fuel from the shell, get power gtl diesel, load the car without heating the vehicle, and if you did something about the electrical component in your vehicle, the important brain memory is getting confused, connect the computer to the computer errors, I think it is okay to replace parts for the undesired bugs [/ QUOTE]
I guess the vehicle is out of sight, gasoline
08.05.2020 17:10 # 6
MBozkurt
it is so abnormal to burn so much, ultimately 1.4 engine.
08.05.2020 17:10 # 7
pierson
Hello friends ... I bought a pegueot 206 xr auto 1.4 vehicle and registered in the forum ... 2002 model car ... I just started driving, so I got automatic gear ... but I have the problem ... FUEL ... I think this vehicle burns in the city ... I bought 50 TL gasoline ... I traveled 70 km and the light started to light up ... what should I do ... I would be very happy if you inform me about car maintenance and use ... < div> teşekküler
08.05.2020 17:10 # 8
Serkan
[QUOTE = pierson] hello guys ... i bought pegueot 206 xr auto 1.4 car and registered in the forum ... 2002 model car ... i just started driving car so i got automatic gear ... but i have this problem .. . FUEL ... this vehicle burns in the city I think ... I bought 50 TL gasoline ... I traveled 70 km and the light started to light ... what should I do ... and if you inform me about car maintenance and use too I would be glad ...
establishments
Dear sir, first of all, if you do not know the maintenance history, change the engine oil, oil, air and pollen filters immediately.
08.05.2020 17:10 # 9
pierson
Thank you. Also how long does this car go when the fuel light turns on ... what do I need to know about this vehicle ... which oil should I use ... how can I find the filters ..
08.05.2020 17:10 # 10
pierson
[QUOTE = pierson] thank you. Also how long does this car go when the fuel light turns on ... what do I need to know about this vehicle ... which oil should I use ... how do I find the filters .. [/ QUOTE]
What should I do about this FUEL? Do I have to wear lpg? I use the city in general ... I traveled 2 km or 5 km sometimes 1 km and parked the car ... I made a road with 40 TL and 70 km using this ... is this normal?
08.05.2020 17:10 # 11
Serkan
[QUOTE = pierson] [QUOTE = pierson] thank you, and how long does this car go when the fuel light turns on ... what do I need to know about this vehicle ... which oil should I use ... how do I find the filters .. [ / QUOTE]
What should I do about this fuel? Should I have an LPG? I am driving in the city. I usually use 2 km or 5 km sometimes 1 km and park the car. .. is this normal? then the vehicle reaches normal fuel values, if you get lpg, you will go with 1-2 km of petrol in the winter. Available from _blank "rel =" nofollow "> http://www.peugeotmarket.com/
08.05.2020 17:10 # 12
engin
fuel is very normal for winter or urban traffic is a short distance or something, I have a 2011 model 1.4 in the winter between 450 and 500 in the city varies between 220 and 250. In my opinion, the normal 5 or 10 km road for the petrol vehicle 20 & nbsp ; If you take 30 minutes, whatever the vehicle is
08.05.2020 17:10 # 13
bjkamil
says 11.4 / 100 km & nbsp; compared to the on-board computer in my vehicle. It passes 50 cents per km. I called the service. said the valve may need to be adjusted. My car 1.4 gasoline 206
08.05.2020 17:10 # 14
Peregrin
Hello friends,
We have been using the vehicle in my signature since February. Unfortunately for these vehicles, around 50 cents is normal. Especially when it is in the city. It was below 50 before the tax hike, now it's over. The road traveled is 10km, 10km and arrival E-5 traffic. Meanwhile, 10,000 maintenance has been done.
