Front wipers do not lift
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:30 # 1
emrahi
I don't think the front wipers of the 208's are up, guys? So it will be destroyed in the winter, the original wipers Cry I would appreciate if friends who knows write ... emrah is 2017-08-14 22:44:03
08.05.2020 20:30 # 2
Furkan979
It has a service mode, you can do it with a wiper arm, after you do it, turn the ignition off and if you take the wiper arm down within 10 seconds, the wipers will come out in the air and stay there.
08.05.2020 20:30 # 3
Furkan979
In this video, the man is doing the same, if it does, it works.
https://youtu.be/dqmmnts3uxs
08.05.2020 20:30 # 4
just like our friend said, switch off the ignition and press down on the wiper arm once it stays in the up position. then you can remove it.
08.05.2020 20:30 # 5
emrahi
I researched before opening the topic to the forum, I found the service mode you said on the internet, I tried but it did not. I tried to put it back into service mode to make sure that you said the same thing, and it did not happen again. I called "Pevgeot Deniz" and asked the technical service, said the wiper will not lift, the master comes to the service mode but he does not get up in the air like tofaş. Smile
08.05.2020 20:30 # 6
talip206
[QUOTE = emrahi] I researched before opening the topic to the forum, I found the service mode you said on the internet, I tried but it did not. I tried to put it back into service mode to make sure that you said the same thing, and it did not happen again. I called "Pevgeot Deniz" and asked the technical service, said the wiper will not lift, the master comes to the service mode but he does not get up in the air like tofaş. Smile [/ QUOTE]
So what to do when the wiper needs to be replaced.
08.05.2020 20:30 # 7
emrahi
[QUOTE = talip206] [QUOTE = emrah] I researched before opening the topic to the forum, I found the service mode you said on the internet, I tried but it did not. I tried to put it back into service mode to make sure that you said the same thing, and it did not happen again. I called "Pevgeot Deniz" and asked the technical service, said the wiper will not lift, the master comes to the service mode but he does not get up in the air like tofaş. Smile [/ QUOTE]
So what to do when the wiper needs to be replaced. [/ QUOTE]
Teacher, it is enough to lift the wiper 10 cm to replace the wiper broom, there are varieties such as broom change snap or latch. It goes out of the windshield, but it is 20 degrees of angle, and with the support of hand, it sticks to the glass again when it is released.
