front voice
08.05.2020 17:33 # 1
secur73
friends, the first time the car runs, it sounds like ciyk ciyk from the front.3- It takes 5 seconds and the sound disappears.
08.05.2020 17:33 # 2
samet206
As far as I know, the timing sound does not do anything, so if it does not do anything if it is certain that it wears out, I do not fully understand it, but the starter gears were damaged if the problem occurred while I was working first.
08.05.2020 17:33 # 3
rolandgarros
it seemed to me not a timing either, but I couldn't diagnose Embarrassed
08.05.2020 17:33 # 4
okan77
It may have a belt attached to the crank pulley and dynamo. You can get the same sound in sudden gases when the vehicle is idle. With heat, the belt may have made a millimeter expansion. tensioner can be controlled.
08.05.2020 17:33 # 5
impact
I replaced the 97% crankshaft pulley, after 4 months, started to crow again.
08.05.2020 17:33 # 6
secur73
thanks...
08.05.2020 17:33 # 7
-ayhan-
it could be a crank pulley, it was singing for me, then it broke in traffic and when it got stuck, the sound was cut off, now the little one is coming again but :(
