Front voice
08.05.2020 16:36 # 1
bahadiryor
When I start my car, turn the steering wheel and take off, I hear a sound like a lak in front of them, why does this sound? Does the vehicle want a front-end now? & nbsp;
08.05.2020 16:36 # 2
Cmoss06
How could I not understand exactly how to turn the steering wheel?
08.05.2020 16:36 # 3
___KxL___
There is a problem with the front team, probably brother. It may be due to the Z rot or swings.
08.05.2020 16:36 # 4
bahadiryor
When I take the car out of the park in the morning, I have to take a bend at that time.
08.05.2020 16:36 # 5
Cmoss06
The front team needs to be checked.
08.05.2020 16:36 # 6
metin
when the steering wheel is completely broken (in U-turns), if it is making lacquer, the axles are gone.
08.05.2020 16:36 # 7
djchaos
I had the same problem from the z rods, but I changed not only when I broke the steering wheel, but a sound that made on the bumps and rough roads, thank God, no sound
08.05.2020 16:36 # 8
GiTaRRa
I don't even want to think about the possibility of a steering pump
08.05.2020 16:36 # 9
ozaannn
The pump is not on the rods, absolutely and definitely the axle balls operate the vehicle without moving in a quiet place, if the steering wheel is low, it will sound, and if the axle balls are pumped, the repair is 150 pounds more expensive than the axles.
08.05.2020 16:36 # 10
okankrgz
the steering pump makes a sound even when it turns around, we do not think it will be easy from the flows.
08.05.2020 16:36 # 11
ozaannn
Z rod arm does not make sound when turning the steering wheel.
08.05.2020 16:36 # 12
bahadiryor
Sound comes only when I move. (Imagine I made a turn) Does not sound in the bumps. or not noticed.
08.05.2020 16:36 # 13
by_imp
I was going to open the same subject now, I have the same problem in me for 2-3 days. I feel the sound and impact in the bumps even without making a half turn right or left. I feel the sound and impact.
Reviews
08.05.2020 16:36 # 14
svgkhn
The exact reason for this is ..
& nbsp;
from axles.
& nbsp;
& nbsp;
08.05.2020 16:36 # 15
fireblade
The problem is understandable on the lift or on the ground ... most likely from the axle ...
08.05.2020 16:36 # 16
mucahidyasar34
The same problem was with me, late in the front of the car, press it from right and left. If there is no flexibility in the spring, take the shock absorber head there, head 20-25 pounds, but 30 pounds and so on & nbsp;
08.05.2020 16:36 # 17
Barut
I had the same problem too.
08.05.2020 16:36 # 18
bahadiryor
thanks for the answers. I will take the vehicle at the most convenient time and share the results with you.
08.05.2020 16:36 # 19
fiddle
it may be due to the shock absorber towers ... just like you said, makes a loud sound.
