front tire slope ..
08.05.2020 19:53 # 1
MadTurk_
While my friends were driving with my vehicle, +90 was pulling to the right. Thinking that the balance time of rot was coming, I got the route. facing friend 3mm from the top of the front left wheel. he said he bent in. There was no accident or something, I did not go into any hole hard.
He said there are a few solutions to this, he said, but I don't recommend it. He said that if the tilt of this wheel was more than 6mm, we would take care of it. why might be the problem? what can be done? thanks
front tire size 205 * 45 * 17
madturk_ 2016-06-27 12:45:06
08.05.2020 19:53 # 2
talip206
Correction of the solution. I think there is no other solution. Or I did this, I was bent on the rim, did not keep the balance adjustment, and I changed the rim and the rim on the spare wheel. If the dimensions match, you can. or compelled to go into correction.
08.05.2020 19:53 # 3
MadTurk_
not a bent rim, but a completely inclined wheel inward.
08.05.2020 19:53 # 4
Cyrus35
The same problem arises from the shock absorber or axon trapezoid. Our master did not advise at all, forcing the correction by pressing it, they were fixing it, but it did not take long to get back to the old version. Even though it is not a problem for now, it carries ultimately that car plus extra towing, the car remains unbalanced, the front wheels of my own vehicle are like the camber that the hondaists do to their rear tires. Big smile I am trying hard with the vehicle as I am a bit obsessed with the shock absorber iron at sudden accelerations. Smile Cyrus35 2016-06-28 08:42:26
