Front teams
08.05.2020 16:46 # 1
kiracoglu
I changed the front tie rods when my friends had an examination last February. Yhoktu, which was the sound of ten teams at the time, was very bored, but I changed it because they asked me to change the inspection at the peugeot authorized service. sound is irritating. As you know, when the front teams are broken, the clattering sounds come. What are the parts that change in the front set?
08.05.2020 16:46 # 2
It does not matter whether you have it done in the service, it is important that you use the original parts.
08.05.2020 16:46 # 3
kiracoglu
The master I have built outside is already a peugeot service .. So I will use original parts anyway. & Nbsp;
08.05.2020 16:46 # 4
efe1988
Check the ball joint bellows, if it is old, it has ruptured and took water, especially if it makes a sound when it hangs in the pit when turning.
08.05.2020 16:46 # 5
ismailkaya
I made a new front set, they said 360 TL, I made 300 TL with the bargain in the service. Rod heads, rod handles, steering wheel, I do not know what the ball is.
08.05.2020 16:46 # 6
teoman_40
Friends 2004 307 1.4 hdi shock absorber prices, can anyone suggest a brand?
08.05.2020 16:46 # 7
Cmoss06
Look at the rods if they hit them out
08.05.2020 16:46 # 8
loiz
As you said, if you changed 300 lira left and right, the price was good, even though the service was good. I'm dealing with the undercarriage.
08.05.2020 16:46 # 9
oguzhan29
bro, i show the vehicle to the service, the same original peugeot parts are different between the service and the hawk peugeot.
08.05.2020 16:46 # 10
loiz
I do the price research and look at the prices of the falcon pejo and buy the parts, I do not say that we will buy the parts with the ball when the vehicle is lifted up in the fiber. just because you did it.
08.05.2020 16:46 # 11
esra_16
2002 I have 206 vehicles, all of the front team must change, the master said, when going slowly and returning, while passing through the bump, there are screeching sounds like greasy door that you know when going at normal speed.
08.05.2020 16:46 # 12
esra_16
I did not even wrote at the price, the master said 600 TL, do you think this price is high, is there anyone who knows the service that will make the bursa suitable and original?
08.05.2020 16:46 # 13
kiracoglu
08.05.2020 16:46 # 14
kiracoglu
Thank you very much, I am only on Sunday, I am not allowed to spend time on my car, I think how to look it up already:) & nbsp;
[QUOTE = efe1988] Check the ball joint bellows, if it is old, it is torn and took water, especially if it makes a sound when it hangs in the pit in turns [/ QUOTE] & nbsp;
yes my brother makes me feel especially on the cobblestone road turns .. & nbsp;
Nothing can be felt on the steering wheel, I do not have any trouble about it, but it is as if the steering wheel is a little more softened than it is ..
08.05.2020 16:46 # 15
sezar206
My front team is gone. There are voices in the back. If a little more administration goes like this one more year, the complete undercarriage will be made a year later. triger miriger is a lot of money.
08.05.2020 16:46 # 16
esra_16
I will go to a master tomorrow.
08.05.2020 16:46 # 17
muratoner
& Nbsp; My vehicle was making sounds on turns and light stony roads. 2 rot heads and 2 z rot changed now I don't have a click like stone. Thank goodness I gave 90 TL in total.
08.05.2020 16:46 # 18
kiracoglu
Let's see, I will save it to 90 TL for the job & nbsp; "Smile" kiracoglu 2012-05-18 23:51:04
08.05.2020 16:46 # 19
efsanemurat
When I turn the steering wheel at low speed, I get all the parts of the front parts from the net, the ball joint rod rod, the rod, the rod, the rod, the shock absorber wedge and the balls, I will replace the rear axle bush, I will replace the bidet shock absorbers 6 months ago, I will replace them if they are damaged, I will replace them with extra oil filter. I am going to change the air filter, diesel filter and oil. It is necessary to visit the summer. What do I need to pay attention to when changing them, but there are other pieces that should change in terms of confiture.
08.05.2020 16:46 # 20
teoman_40
[QUOTE = Cmoss06] Z looks at the rods, if it clicks out [/ QUOTE]
I did not see the shock absorber, Z rods and the right rot head changed, the problem was resolved :)))
