Front team swing and tie rods
08.05.2020 17:13 # 1
eroglu
disturbing sound on the road and & nbsp; When the first lift is lifted, the results for the sound coming from the wheel region at full turns will change the rod rods and swings, the prices of 280 TL labor 75 TL total 355 TL normal do you think? What happens if I do not have it? What happens if I buy a new tire without having it made?
08.05.2020 17:13 # 2
KenBlockJR
I think it's too much. especially craftsmanship. If it is not done, the rod arm makes a loud sound, although it is not felt in single pits, it disturbs on rough roads.
08.05.2020 17:13 # 3
eroglu
thank you brother would like to hear that more suggestions come.
08.05.2020 17:13 # 4
207TAKSI
08.05.2020 17:13 # 5
SDYMZ
I think you should have it, the space in the rod arm increases, it can be removed while going on the road, the room will cause greater damage. Get the parts yourself. After the arm changes, you need to go to the rot setting, it takes 50 TL or so
08.05.2020 17:13 # 6
hLL
I have the same problem.
08.05.2020 17:13 # 7
Muratkar
Greetings Eroglu, I have the same problem, I will be in 45000 maintenance, I will show there.
What did you do, did you continue without doing or did you do it?
08.05.2020 17:13 # 8
eroglu
As bro, I made two swings, a tie rod and an oil change of 350 TL, of course, the industry is a sub-industry, but the result is very good, even if the handling has changed, come on the weekend, let me go to the master, maybe he will do 400 to you, but it will be the most oil. I don't know if there would be a difference between filter and gas filter in my car alone.
08.05.2020 17:13 # 9
SDYMZ
may be in the engine ear or transmission ear
08.05.2020 17:13 # 10
Muratkar
Eroglu Kardeş,
I am going to go to the rock pejo in Izmir this Saturday Saturday, who was your master. ..? Reviews
Reviews
08.05.2020 17:13 # 11
eroglu
I always know the parts come from izmir, I think you can search the parts thoroughly and buy them to any master who understands from pejo, but first, a few rot balancer or go ask them to investigate. Even though I was not happy with the grip, I bought zero michelin on the front tires, I came to my own mind. Search the place by comparing it and buy it. I do not know the engine oil, but I learned the price of the parts, I went to the master, I said that these parts will happen. I said more than 5 TL.
08.05.2020 17:13 # 12
Muratkar
my teacher, you can get the full filter set + 5w40 oil from 150 TL for the original pejo. A sound coming on the way. It started to annoy, it should be done without dangerous.
08.05.2020 17:13 # 13
eroglu
If I had a good machine due to the aging of the plastic on the swings, I would pull it and put it in repair, that is, think from shoulder to hand, the joint will be worn in the shoulder area and the sound that will come out when trying to draw a circle with your arm will be that sound.
08.05.2020 17:13 # 14
Muratkar
I hope it is as you said, hodja, let's see gorucez I write here my problem and solution ...
08.05.2020 17:13 # 15
Muratkar
I went to the tie rod connector for this problem, the problem was just the tires.
the tires are very important.
