Front sprinkler does not work
Homepage » PEUGEOT MODIFIED PLATFORM » 106
08.05.2020 19:33 # 1
medcvt
My 106 xr car's rear window sprinkler is spraying water but they do not. medcvt 2015-12-16 20:31:56
08.05.2020 19:33 # 2
bayraktarcetin
The sprinklers may be clogged.
08.05.2020 19:33 # 3
It is probably blocked by lime.
08.05.2020 19:33 # 4
ismailkaya
The sprinkler motor has two outlets, apart from it, with a pair of pliers, and there is an independent stopper, where it is a mud bury function. Good luck with
08.05.2020 19:33 # 5
medcvt
When I try to run the front sprinklers, there is no sound from the sprinkler engine, but I want to wipe the back working as you said.
08.05.2020 19:33 # 6
medcvt
the electrician looked a little bit of trouble, he said on the handle, he gave the front sprinkler while the motor turned forward, he gave the back sprinkler while returning he said he ran the front sprinkler from the cables. . Tongue
08.05.2020 19:33 # 7
Htc
[QUOTE = medcvt] the electrician, who was in trouble, looked a bit in the arm, said in the arm, he gave the front sprinkler while the motor turned forward, he gave the back sprinkler while returning, he said, he ran the front sprinkler from the cables. tşk ..... Tongue [/ QUOTE]
Since 70% of the problem is faced with the obstruction, thanks to the help of a collective needle including me, the answer is obstructed. .I have not been able to match this word to the site I have been following for months and I could not write it as CVP.
08.05.2020 19:33 # 8
ALLEX
[QUOTE = Htc] [QUOTE = medcvt] the electrician, who was in trouble, looked a little bit, said in the arm, he gave the front sprinkler while the motor turned forward, he gave the back sprinkler when he came back, the front sprinkler from the cables was running, meanwhile, anyone who does not know is clogged, a logical answer, let's find a solution accordingly. Thank you to all friends who couldn't help ..... Tongue [/ QUOTE]
Since 70% of the problem is faced with the obstruction, thanks to the help of a collective needle including me, the answer is obstructed. .I have not been able to match this word to the site I have been following for months and I could not write it as CVP. [/ QUOTE]
I agree exactly .. Clap
Also, our friend could have made an attempt even by guessing the fountain's working system, but could have consulted someone.
The problem he spoke about could also happen in any vehicle that did not notice the brand model.
I guess only those who have a steering driver. So instead of getting on the old model car, let's rent a last model tomofil .ona get on every month .. Thumbs Down
