front logo revocation 307
08.05.2020 15:53 # 1
I am thinking of having it done, but I have questions in my mind. First of all, would it be useful in terms of getting air to the engine, etc. or just my image?
08.05.2020 15:53 # 2
riva70
what's the need
08.05.2020 15:53 # 3
The obsession has occurred like the engine is airless. For some reason, when the air conditioner is turned on, the air conditioner is turned off, it does not realize that it does not exceed 80 because the fan is running, but it does not fall below 90 when the air conditioner is turned off. I think it will be a plain image, but I am not sure.
08.05.2020 15:53 # 4
I do not want to say this in medicine, do not do it in the evening.
08.05.2020 15:53 # 5
:) brother, there are 3 familiar masters, 2 of them in Istanbul and 1 of them all cause different reasons. There may be no problem, the weather does not exceed the hot line after 90. I have used a lot of diesel cars.
08.05.2020 15:53 # 6
[QUOTE = hcthct] :) brother, there are 3 familiar masters, 2 of them in Istanbul, 1 of them all cause a different reason. QUOTE]
i think they are not a master, you can go to maslak auto industry if you are in istanbul cecoli brother can recommend you a very good master
08.05.2020 15:53 # 7
I'm in Istanbul until September, but I have an internship now.
08.05.2020 15:53 # 8
Why is it not normal anyway to stop at 90 or why you put it on, if the channels are not enough, the engineers who designed it would not put that logo there, wouldn't it take the original air from the lower grills or would it save you a small logo? Confused
08.05.2020 15:53 # 9
obsession :) When I was very young, the bus was overheated, our water tank was exploding or something.
08.05.2020 15:53 # 10
I am also obsessed, but if 90 is good, they wouldn't reveal if it was bad, right? Sırıtma
I also went between 80-90 on the normal cruise, traffic was blocked yesterday, then it approached a 100, when I got over the jam, I went down to 90, I think this means no problem :)
08.05.2020 15:53 # 11
low rises too high they say the temperature is over, I raised up to 45, the speed of the gear has increased so much did not increase, but stop and climb directly up to 100
