Front Layout System ....
08.05.2020 15:21 # 1
PRE-ORDER SYSTEM
Pre-order system,
provides the rotation of the vehicle. Steering wheel, steering shaft, worm gear, sector gear, tie rod, curved rod, short rod, tie rod end are some parts of this system.
Steering gear oil should be checked. Pulling, traveling etc. in the vehicle If there is any, service should be done. It has settings such as Camber / Caster / King-pin / tie rod and steering box settings. Imperfection and wear of the gears increases the steering gap.
Also the wear of the tie rod heads and steering box failures steering gap < / b> increases.
If the front layout settings are broken, the front tires will wear out from the inside and outside.
If the steering wheel turns difficult, the tire pressure is less than normal.
SUSPENSION SYSTEM
Suspension system,
is the system where vehicle wheels are combined with the chassis and body of the vehicle. It consists of springs (coil springs), leaf springs (scissors) and shock absorbers.
Coil springs are generally used in heavy duty vehicles, while shears are used in automobile type vehicles.
Springs, take on impact vibrations from the road. shock absorber controls the release of springs.
