front layout
29.08.2021 21:58 # 1
oates55
Friends, when turning right or left from the front row, there is a cit sound. Because of this insignificant sound in my 2002 model car, we decided to renew the entire front arrangement such as shock absorbers, swing, tie rod, shaft. Do you think it would be better if I changed these parts in my 19-year-old car, or would I face an irregularity if I did?
29.08.2021 23:15 # 2
sozuak
When you replace the shock absorbers, put the old ones aside. Even if you're going to install a sub-industry or junk brand shock absorber, you'll regret having the old ones repaired and put back on.
I did the same, I had it renewed, it was fine, but when I said zero shock absorber is good in every way, I renewed it, although there was no problem, the shock absorber said you will regret it, I regretted it. You can't get that comfort with anyone other than the original.
Show it to the shock absorber without removing the shock absorbers then listen to his advice on shock absorbers.
If there is no problem with other parts, most of the aftermarket parts start to make noise within 1 year, so either find a quality part or identify the source of the sound (probably the shock absorber balls) them and their wedges. refresh skip skip.
29.08.2021 23:20 # 3
oates55
3 shock absorbers burst .. I will have 4 high quality shock absorbers and parts fitted. But I wonder if I should install parts such as the swingarms, tie rod shaft, tie rod head or not.
30.08.2021 02:05 # 4
sozuak
Once the undercarriage is disbanded, most of them cannot be reattached anyway. If you are trying to do such a big job, go ahead, but with quality parts. Some are damaged when removed.
