Front hood not closing problem
08.05.2020 20:49 # 1
Ahmetaltay
Hello friends, I just joined you. My car is 2004 model 307 sw. I opened the hood to look at the oil and water and I couldn't close it again. anybody come in? thanks in advance
08.05.2020 20:49 # 2
onlycihan
Sometimes the lock spindle rotates automatically and the hood does not close, as the need for the open pit is closed. This may also happen on other doors. Check that part, pull back, it will close
08.05.2020 20:49 # 3
Sometimes it can happen, as our friend says, or there is a key problem, you may need to change it.
08.05.2020 20:49 # 4
Cyrus35
Check your latch from the inside. The cable pulled by the latch may be broken or twisted. If you pull it out, you cannot manually release the tongue.
