Front headlight
08.05.2020 21:13 # 1
kaan206
if I buy the headlight assembly for friends 206
Does it come with 1-bulbs?
Is there a headlight height adjustment motor inside?
3-Is there adjustment screw on both headlights to adjust the right-left angle?
08.05.2020 21:13 # 2
Brcbyrktr
My brother, I bought headlights with the same questions in my head a while ago.
Question 1: No, you have to buy the bulbs separately.
Question 2: The headlight height motor should be a separate apparatus attached to the headlight, so it should be you.
Question 3: Yes. After I had the headlamp installed, I took it to the tuner and they were adjusting on both sides.
08.05.2020 21:13 # 3
kaan206
height adjustment motors in bnm headlights are defective
I understand it is correct to say that the height adjustment motors are not coming when you get a new headlight.
When they go to the adjuster, does the place where it adjusts does not come to zero in the new headlight or they remove it from the old headlight.
So when you get a new headlight, the headlight height adjustment engine and the part where fine tuning is done is not displayed.
What brand you bought is not good, if you can not get the original, they say warehouse brand sl
kaan206 2019-04-27 23:14:26
08.05.2020 21:13 # 4
kaan206
? kaan206 2019-04-28 23:08:27
08.05.2020 21:13 # 5
Unfortunately, the headlight when you take the skin does not have a headlight height adjustment, minus the headlamps. Ayfar lighting is very bad and the light is ok. The warehouse brand is better in this regard.
08.05.2020 21:13 # 6
kaan206
I ordered yesterday warehouse headlight right and left and 2 height adjustment engines. My headlights are so bad I can't drive at night :)
08.05.2020 21:13 # 7
Come on, you could use the headlight adjustment motors at the top of your existing headlights, unless it is defective :)
08.05.2020 21:13 # 8
kaan206
already had headlight adjustment motors 😁 headlight rear covers were not connected through broken original cable entries
Best of all, I reset it, I said you were intact. I was driving my car out of the window at night and driving
kaan206 2019-05-29 21:21:53
08.05.2020 21:13 # 9
kaan206
friends, I bought zero tank headlight
I have a question alone?
Dipped beam headlight adjustment is made separately.
I am satisfied with the adjustment of the dipped beams, but the high beam adjustment is not good. Is the dipped beam headlamp and the high beam adjustment on the headlamp separately?
I don't mean the headlight height adjustment
