Front Fender removal hk
08.05.2020 17:46 # 1
myvzklc
Peugeot 307 How can I remove the left front fender, can you help me guys? myvzklc 2013-07-06 12:39:51
08.05.2020 17:46 # 2
Hasan Emre
Hodja, even if there is no fault in the car, fln diols played with this piece will let you down. .
If we come to how to disassemble it, I have never removed the 307, but in general it is the same. I tell you.
First, remove the screws on the top surface that appears when he opened the hood, did they put the headlight under the headlight. Take it out, open the door and look inwards. Is there a screw? There is a long mouth for this. There is no joke. . You unscrew the visible screws, then it is slightly muscular where you have the screw where you can see the tutu. . : D
Reviews
08.05.2020 17:46 # 3
myvzklc
Trial and error method ie & nbsp; "Smile"
08.05.2020 17:46 # 4
reality59
C4AG0XF1 - 307 REMOVAL - REFITTING FRONT FENDER1 - REMOVE open the hood. Unscrew the fixing points (1) by turning one quarter turn. Remove the front fender clips from (A). Remove: the fasteners (3) the fixing clip (4) (B) disengage the front fender from the clips (Be careful not to break the retainer parts). (Front right fender: Only) .2 - REFITTING MUST: Put the canister head (5) back into its seat (front right fender: only) while re-attaching the fender. then install the upper fixing: Scan front post fi. Rotate the fixing points (1) by rotating a quarter turn, then attach the bottom fixing: Front post side. Re-attach the central fixing point: Front post side. Re-clip the fender at (B). clip (4) reality592013-07-06 13:04:35
08.05.2020 17:46 # 5
peugeot3535
it was a very good resource. Do you know a source where we can find diagrams of other peugeot models & nbsp;
thanks
