Front door speaker replacement |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 14:16 | # 1 |
The 2001 model has 206 XT, when I bought it, it replaced the original tape and replaced it with a goldmaster mp3 player tape (4x45W). Now I don't like the original speakers of this, instead I bought 1 pair of Pioneer TS-G1642R 16cm for the front, 1 pair of Pioneer TS-G1343R 13cm for the rear. I wouldn't be able to add them to the forum if I can change them if I change them and I couldn't find how to remove the front door speaker.
| 08.05.2020 14:16 | # 2 |
Melih |
I changed the front door speakers of my 99 206 xt pioneer 16 I bought the perforated plastic cover on the door with a screwdriver.
| 08.05.2020 14:16 | # 3 |
there is Doesn't this work by removing the door trim? I was thinking that the door trim would be removed in front of me. Of course there is no need to say the following quote, but
| 08.05.2020 14:16 | # 4 |
Melih |
There is a master who told me about it, but I couldn't find how to remove the door opening handle and the glass lifting arm.
| 08.05.2020 14:16 | # 5 |
I haven't looked at it yet, but I'll try to get it done tomorrow ... if someone writes an answer today, I can do it or muscle strength .... |
| 08.05.2020 14:16 | # 6 |
algn place will wear it at no cost :)
| 08.05.2020 14:16 | # 7 |
I bought it from the net, so I fell into trouble with myself. |
| 08.05.2020 14:16 | # 8 |
i finished this job soon i will add the pictures ... |
| 08.05.2020 14:16 | # 9 |
barisaso |
How do I sound good?
| 08.05.2020 14:16 | # 10 |
NOT GOOD AS I EXPECTED, GOOD, BUT A GOOD SOUND WITH A SEAT SEAT WOOFER A GOOD SOUND WITHOUT A STICK, I WOULD TAKE A BEAUTIFUL BASIC SOUND.
| 08.05.2020 14:16 | # 11 |
bro |
[QUOTE = syz33] IT IS NOT AS I LIKE EXPECTED GOOD, BUT A GOOD SOUND WITHOUT A GOLDEN CHOICE IF I RECEIVE A SINGLE SEAT WOOFER A SINGLE EQUAL BASIC SOUND [/ QUOTE] I wonder if the desired sound is not received from the speakers you bought? What if you do, can't you get more performance? I think I will have the same problem as well when the car comes in. I have a little bit of bass disease.
| 08.05.2020 14:16 | # 12 |
bro |
I was a little bit stuck today and found a few models. 16 cm; It has 70W rms, 210W peak. This is a little salty but Rms 100W I heard the Harward name a lot, but it was my speaker, it was my amphitheater. 13 cm; I heard this brand for the first time but it says 90W Rms is correct. There are 65W Rms, but I go and find the most expensive This process is solved with a subwoofer such as http://www.alpine-electronics.com.tr/ueruenler/product-singleview/powered-subwoofer-boxes/swe-1000.html and a 4 output JBL Amplifier under the armpit This armpit sub. I like the job very much, if I find a suitable one, I will definitely buy it.
| 08.05.2020 14:16 | # 13 |
bless your hands
| 08.05.2020 14:16 | # 14 |
friends, what is this component event? I bought a new 206+ and I will do something related to the sound, but what: D ... I think it will be enough if I put speakers inside the door ...
| 08.05.2020 14:16 | # 15 |
You must have an anfin with a 4 channel 2 channel or 5 channel stero output. complar does not work without amphitheater. you will get a cox 2 way 3 way hop performance. you should buy 16cm comp on the front, 13cm on the back but if you put the comp on the back doors, your windows will not drop down. you should buy the narrowest comp in the magnet part, the room will be perforated to the back, it will be like a normal hop. en guseli Güsel Take 2 pieces of 16cm, 2 pieces of 13cm hop. ii mods ii forums it was like a general cvp :) |
| 08.05.2020 14:16 | # 16 |
Thanks for the answer, my friend, for example, I did not think that the glass will not come down, as you said, it makes the most sense to do it ... I think it will satisfy me if I buy something nice in the front and middle sugar in the back ... http://www.hepsiburada.com/liste/navitech-cs-k-5013-13-cm-coaxial-4-yollu-hoparlor/productdetails.aspx?productıd=otdelcsk5013&categoryıd=26090 http://www.hepsiburada.com/liste/navitech-cs-k-5069-6x9-4-yollu-hoparlor/productdetails.aspx?productıd=otdelcsk5069&categoryıd=26090 this duo or .. http://www.sadeceelektronik.com/?urun-6688-sony-xs-gtf1625b-16cm-190watt-hoparlor.html |
| 08.05.2020 14:16 | # 17 |
evt comp work is costly and costly I applied 16cm front and 13cm focal to the front comp .. amphitheater 5 channel 4 output streo 1 output mofset basda kicker cvx 38`` 9885 r alpine in my headunit I do not count the cables fuse capasitor long business seriously entering: S
