Front console painting
08.05.2020 21:08 # 1
Aykutemre92
I painted the front console before, this tape is where I want to paint the door handles or something but this time by applying a primer and changing the color better. How can I remove the paint I used before? Will the paint remover melt the plastic if I use the spray? Help please
08.05.2020 21:08 # 2
GokhaN
You will have to put the paint on it.
piece plastic bidet expensive no hassle direct paint
08.05.2020 21:08 # 3
If you try to remove it, it might be worse. I would make a nice water sandpaper. Then, I do not forget to apply a plastic varnish and a matt varnish as you know :)
08.05.2020 21:08 # 4
Aykutemre92
Isn't there a way to remove acrylic paint from plastic trim?
08.05.2020 21:08 # 5
Karacocuk24
soner peeled sandpaper primer paint varnish
08.05.2020 21:08 # 6
[QUOTE = Aykutemre92] Is there a need to remove acrylic paint on plastic trim? [/ QUOTE]
There are dye-removing chemicals, but it can cause damage. You can take the paint remover by spraying it, but as soon as the paint comes out, rinse well with warm water.
08.05.2020 21:08 # 7
Aykutemre92
[QUOTE = sonerkyl] it would be worse if you try to remove it exactly.
Does the primer adhere to the paint?
08.05.2020 21:08 # 8
HakanYksl16
[QUOTE = Aykutemre92] I painted the front console before, this tape is where I want to paint the door handles or something but this time by applying a primer and changing the color better. How can I remove the paint I used before? Will the paint remover melt the plastic if I use the spray? Help please [/ QUOTE]
I guess you did not use varnish and primer after painting. So how long was the life average of the paint?
08.05.2020 21:08 # 9
Aykutemre92
I used varnish right now, I removed the door opening frames and sprayed it with paint sprayer. The paint has been fading for 6 months.
