Front and Rear Tool Repair
11.07.2021 11:04 # 1
Sail
Friends, I went to the root balancer and had the front and rear kits checked. My car is squeaking from the bottom. It would come on when I turned the steering wheel to the right. He looked and wrote the following on the paper.
right left z rot
right left table
right left front rear shock absorber
right left rear torsion flares
There is not much else left :) Do you think it is necessary to have these done urgently? Because where I am, the roads are bad, I think it will deteriorate in a short time. I guess it's not something that will leave you on the road, but do you think it will cause other things to deteriorate? Would it be enough if I only did the first three items? Thank youSmile
12.07.2021 20:54 # 2
talip206
He has a life of 1 year on the roads of our country, sir.
It'll be fine if you get the first 3 done. Torsion is already a cost in itself. Torsion alone costs a thousand pounds at best. The squeak coming from the back usually comes from torsion.
13.07.2021 12:33 # 3
SLTPEJO
I just had a torsion done. I paid 1100 TL and it didn't work. The sounds from below are driving me crazy. The same mechanic is now saying that you couldn't hear this from the torsion sound that will change in the front gear.. I gave up, I'm not getting anything done. I turn the music up a little too much, the sounds are cut off :)
13.07.2021 15:16 # 4
Sail
Master, should I give a thousand liras every year :(
Then I say let it stay like this :))
But there is an examination this year... There is a slight flaw in the examination maybe
13.07.2021 15:17 # 5
Sail
Master, they gave you a price again. The master tells me it takes 1200 lathes. Labor at 200 :)
