FROM FRONT
08.05.2020 20:48 # 1
307XS307
Hi friends my car 2004 model 307 xs 1.6 auto petrol lpg li.
When I get out of the car I noticed for the last 1 month, there is a smell like a burnt smell. As if the car overheats, it smells like a stench. sometimes I thought it was coming from the wheels because i used it fast but today i realized it comes from the front. I did not open the hood, but I sniffed at the top of the plate, in short, it comes from the front. what could be the reason for this
There were those who said that the pressure is the smell of the lining. but some also say that the auto-gear car won't have a pressure pad. In addition, because the car is automatic, the engine brakes, though it did not do when it was on the gas, but I feel the engine braking slow down after I have fitted the LPG or something.
does not give any warning in the car. I looked at the oil and the water of them. though it has been 8-9 months since I bought the car.
But I can think of something, but I'm just starting to learn the traits of this car, but after I got the lpg, I got it right after I got the car. this vehicle started to scream a lot after 110 km. I recently said I should press a long way again.
08.05.2020 20:48 # 2
307XS307
I also forgot to write. Since the vehicle is automatic, it slows down and shifts its engine, and I can do it in hard brakes when I use it fast, stop and stop in traffic. I wonder if this engine brake event is exhausting the engine so it could be this smell
08.05.2020 20:48 # 3
boruc
It smells like a plastic burnt smell when it comes to me.
Something like nylon and sachet stuck to the part of the exhaust under the engine.
It could be in such a simple situation
08.05.2020 20:48 # 4
something might have stuck as our friend said. Or if there is a short circuit in some place, it can come from the cables, I think, have a good control as soon as possible. There is a possibility that it may also be caused by the catalyst. But I would like to see the priority LPG electrical installation.
08.05.2020 20:48 # 5
onurrr41
Sir, there was the same smell on me;
1. possibility: The bag sticks to the exhaust (smells for months if you don't scrape off)
2. Possibility: the plastic that holds your oil filter is cracked or broken. The oil dripping from the oil filter and dripping onto the manifold may emit this odor (my smell came from here)
3. possibility: you left the car in the cold, cold the kidneys 😅 😅
