Friends with information about 407.
08.05.2020 16:49 # 1
eerkan
friends want to get 407 can you give me information about 407 they say very problematic tool in some forums they hit as they hit & nbsp; What do you think, I am a new sleeper, I do not know if I am right to write in this area. Sorry, thanks.
08.05.2020 16:49 # 2
Regardless of which brand-model, the vehicle you will buy will be second hand and how the previous users will use the tool will be an indicator of how much problems you will have in the future. I recommend that you make a decision only by asking more than one master before buying. In addition, 407 is a very beautiful and spacious vehicle. I do not think the coupe version in Turkey is gearing up, but I think one of the most beautiful instrument. Reviews
08.05.2020 16:49 # 3
eerkan
I like it very much. If I need to talk openly, I was thinking about Mondeo. I did not find a safe, I wanted to find a car, I said 407, I found it, I searched for a few things, everything says good, but I think I should visit the forums for the other forums. respects.
08.05.2020 16:49 # 4
eerkan
In the 407s, the engine malfunction is too high and the malfunction cannot be found from time to time.
08.05.2020 16:49 # 5
Cmoss06
The vehicle with a chronical malfunction is not taken to traffic. Generally the same kind of & nbsp; malfunctions are chronical malfunction & nbsp; in Turkey.
08.05.2020 16:49 # 6
toga406
Apart from hitting the ground, a comfortable luxury vehicle has the same engine as the focus la and volvo s40s. enough luggage. those sitting in the back handle the bass distance.
is more than enough
08.05.2020 16:49 # 7
eerkan
friends, I couldn't explain, I guess, vehicle malfunction is happening too, what are the friends using the fate & nbsp; No brother, they say, keep an eye on, or say they are far away. Thank you.
08.05.2020 16:49 # 8
toga406
there can be no engine malfunction. It gives the most turbo problems, a little sans depending on the use of the room.
08.05.2020 16:49 # 9
[QUOTE] No bro, they say "keep your eyes closed" or say they are far away. Thank you.
Nothing like that. The two ends came to the head and spread word of mouth from ear to ear. Reviews
08.05.2020 16:49 # 10
toga406
If you don't care about 407 nearby places, I would take this immediately. diesel but I say take a comfort
08.05.2020 16:49 # 11
eerkan
no I am thinking of buying a 2.0 gasoline straight 407, how good is the exec.model.
08.05.2020 16:49 # 12
toga406
[QUOTE = eerkan] no I am thinking of buying a 2.0 gasoline straight 407 how do I make the exec.model.
I think if you decide on this model, go get 2.0 hdi bva. machine performance and fuel price is also reasonable I think
08.05.2020 16:49 # 13
sfirat035
Peugeot & nbsp; 407 malfunction does not happen on time and if you use the vehicle cyclically, it will never fail. I have been using 407 since 2008, I always go to izmir and come to Istanbul, I am filling a warehouse with a lot of fuel in terms of fuel. I tried really going, I don't believe in the beginning but I am true & nbsp;
08.05.2020 16:49 # 14
sfirat035
Peugeot & nbsp; 407 malfunction does not happen on time, and if you use the vehicle cycle, I will never fail. I arrive at izmir before the fuel gauge is halfway. 1450 km is going with full tank. I tried this.
08.05.2020 16:49 # 15
mami202
If you are going to buy the manual automatically, I recommend you to look at 2006 and above models (the information screen is colored) Other orange models are orange. I use the 2005 model 2.0 executive automatic transmission (sw chassis at 140000). The front of the vehicle should pay attention to the bumps near the ground. You can rub the bottom of the plate or if you entered too hard, put the middle part in the bowl. You should pay attention to the parking lot entrances and exits. a vehicle that causes a speed limit violation.triger set factory data has 10 years of life If you think of the roads of our country, it falls to 7 years. you get it by checking it, I have not seen anything negative for the engine so far, even in spite of all the negative situations in my vehicle (transmission catalyst is problematic), a machine that performs 200 km in such a good performance, thank goodness did not arise. Ideal comfort for long road comfort confidence is satisfactory when it enters the corner I think the most obvious example of trust is to press the gas instead of slowing down the car already full abs esp asr parking sensor speed control and cruise control rain, headlight sensor child lock etc. snow and sports mode in automobiles, a model that meets the expectations of a vehicle, is a bit difficult to use, it is quite economical if you take the weight of the chassis under 1.5 liters in city and mixed use (1.5 tons). Don't buy cheap tires, these important front and rear bumpers are both robust and flexible, so you will not experience situations such as breakage, spillage in small-scale accidents, as long as you use the original parts and do not easily break down after you do their normal maintenance. Sample prices of some parts front discs 200 tl maximum pads 60 to 90 tl trianger set including recirculation labor 500 tlotomatic transmission complete reset 3000 tl maximumlastic price 400 tl maximumservofren 250 tl maximum tax for 7-12 age group 1 year 1040 tl mami2022013-08-04 22:31:04
08.05.2020 16:49 # 16
mami202
By the way, I realized later that you would get a flat gear & nbsp;
good luck ..
mami202 2013-08-04 22:33:15
