Friends urgent help please
08.05.2020 20:26 # 1
Baran35
When my friends started the car the other day, the sounds came from the LPG beep beep. After running over 2 days, I run a single starter, took it to the LPG, I changed the filter or something, but there was no problem but today I had the same problem, I pressed the starter a little more and the smoke started to come out from the engine section, then I tried it 5 minutes later, but I did not run the car. My question is why the vehicle does not work and I wonder where the smoke came from. In the meantime, I run the tool in lpg, I press the button constantly and run it does not work in gasoline. I told you a little confused, sorry, I hope I can find care. May your blessed holiday be blessed
