Friends please help!
08.05.2020 18:09 # 1
E.B
Good evening, first of all I wish you many happy healthy years ...
I was talking on the phone while my friends were leaving the mountain 2 days ago. When I came to the top when I said that I had climbed to the top, the engine remained between 3000-4000 rpm, but it did not come to red and did not give a signal. when I came home at 90 o'clock on the flat road, when I looked at it, I saw that the engine water was over, I put it right away, then I realized that the inner mats of the car were wet from the wet area, right under the steering wheel, behind the plastic floor, I saw the water before. There is one thing today, while the mountain comes out, the temperature at 2500 in the normal period has come to 110 again.
I wonder if the car lit the contami? how do i know please but please help :(
08.05.2020 18:09 # 2
kursat3006
Was there any oil in the engine water when you missed it or checked it
08.05.2020 18:09 # 3
E.B
Now I went down and checked it again, I took the water 3 times, but there was no oil, then I pulled out the oil cubes, there was no water in the oil cubes, then I put the water on the lid, I opened the car 3000 cycles, I took it out of the water, I took it out to 4000 and it was throwing 2 3 drops out. I can't find what you're doing: S
08.05.2020 18:09 # 4
Barut
Is the vehicle 307?
08.05.2020 18:09 # 5
Barut
Red dream 2013-12-27 00:39:18
08.05.2020 18:09 # 6
E.B
Yes 307 xsi 2.0
08.05.2020 18:09 # 7
kursat3006
the gasket did not burn then if there is no oil in the engine water. Does the vehicle turn on a fan?
08.05.2020 18:09 # 8
Barut
[QUOTE = EB] Yes 307 xsi 2.0 [/ QUOTE] Chronic in 307s, if there is water in the mats, the radiators of the heating radiator are probably exploded. the same has happened to me in 206, too.
08.05.2020 18:09 # 9
E.B
Believe me, I haven't heard that any fan is acting.
my http://forum.peugeotturkey.com/forum_posts.asp?tıd=20250&title=soutma-suyunun-aracn-%ddine-szmas-proble
I have the same problem that the friend in this link is experiencing.
08.05.2020 18:09 # 10
Barut
Naturally, the temperature rises because there is no water left in the vehicle. Examine the subject you can do it yourself.
08.05.2020 18:09 # 11
E.B
when the temperature rises only when I wonder and check there was water inside, couldn't there be enough water due to the cracks in these pipes? How can I tell if the car burns gasket?
08.05.2020 18:09 # 12
barishrocker
My fan motor had failed in another vehicle. the fan had 2 stages. when the engine got too hot it had to go to the 2nd stage. The vehicle was not going to the 2nd stage since the 2001 model was old. In winter, the temperature did not rise much, but in summer, the temperature reached the ceiling. then there is no problem when it changes I say look at the fan too. Apart from that, I saw that he was missing from the gasket in a brand new alpha. so you have to check for leaks and leaks;)
