FRIENDS PLEASE FIND A SOLUTION TO THE PROBLEM.
08.05.2020 18:52 # 1
samet2461
friends brothers I can't get answers to any questions I ask. I have a problem right now and I look forward to helping you. I have an electronic EGR on my 307 1.6 diesel, so there is a problem in this egr brain, it stays open all the time and strangles the car at low speed. how can i cancel this. please help me
08.05.2020 18:52 # 2
driver-can
As far as I know, they put the gasket between the egr valve and close it, so it is canceled.
08.05.2020 18:52 # 3
driver-can
The egr cancellation is done by cutting the flat metal gasket to the part of the egr opening to the intake manifold and canceling the transition. burns..so the egr system is left in place and a metal gasket is cut into the mouth of the egr opening to the intake manifold. The valve is left in place. Emission does not play as long as it operates properly. Even the clean air free from exhaust gas enters the intake manifold, combustion is better. It is higher than the vehicle. Emission does not matter too much. It is also because of the increase in power in vehicles with cancellation of the EGR.
08.05.2020 18:52 # 4
samet2461
[QUOTE = driver-can] egr cancellation is done by cutting the flat metal gasket to the part of the egr opening to the intake manifold and canceling the passage. Since the sensor inside will not read, the engine malfunction lamp lights up. Therefore, a metal gasket is cut into the mouth of the EGR that opens to the intake manifold of the EGR system, leaving the valve in place. The exhaust gas that cannot make the energy can be thrown out the same way. .and does not decrease performance ... as long as it works properly in the lamp, emission does not play also .. even the clean air purified from the exhaust gas comes into the intake manifold, the combustion is better ... the aim of egr is to regulate emission by making concessions without burning ... rich mix will make egr ipta It is higher compared to the same vehicle made in. The emission does not matter much either. Therefore, the increase of power in the vehicles with cancellation of the EGR is compared to the previous date.
My teacher has a pipe that mixes the exhaust gas to the intake manifold of the engine. So the place I marked in the picture:
08.05.2020 18:52 # 5
driver-can
I do not think that it will cut the gasket by cutting the gaskets, masters, make it to a master who knows this work.
08.05.2020 18:52 # 6
samet2461
[QUOTE = driver-can] I don't think it will die by cutting the gasket, masters, do this to a master who knows this work [/ QUOTE]
I do not trust the masters here, I say do it myself. I just need some information. it's best to put a gasket where that iron pipe connects to egr. I guess you already mentioned it.
samet2461 2014-11-11 19:42:38
08.05.2020 18:52 # 7
samet2461
Will I close it from the head of the hose where I marked it with my teacher SARI color or is it by the first block that connects to EGR?
samet2461 2014-11-16 00:07:21
08.05.2020 18:52 # 8
ahmetkertik42
Samet my friend thank you very well, if you put the gasket on the back of the valve from the back of the valve, it would be a problem for both the vehicle and you if you put the gasket on the pipe.
08.05.2020 18:52 # 9
samet2461
[QUOTE = ahmetkertik42] Samet my friend thank you very well if you put the gasket on the back part of the valve, if you put that seal on the pipe, there is a coupling on the pipe already.
Thank you. I didn't know that the pipe was closed Smile I will change it to the master, but the masters keep saying that it will not be canceled. thanks Wink
18.09.2025 12:50 # 10
telliogluorhan
How did you do it? What is the result?
