friends help rim tire
08.05.2020 17:45 # 1
hakan6200
mrb friends, since I was a pejo patient since I was a little bit, I got 206 1.4 xr when I started the modification. I would be glad if friends who understand tessekurlar help you get the size brand comfort ..
birde pejo 206 a 5 cm spring or 3.5 mi 5 cm vehicle cause problems
08.05.2020 17:45 # 2
Barut
As a rim, 15 cc is beautiful, as the car is a 1.4 engine, I would say 3.5 springs never drop from 5 cm springs.
08.05.2020 17:45 # 3
hakan6200
I will thank you. Do you have any suggestions for the size of the tire? I really do understand that the tire will be comfortable from the heat of the tire.
08.05.2020 17:45 # 4
samet206
If I have 15 Inch RC Wheels, let me get it :) If you are determined to be 15 Inch, I recommend the 5-spoke wheels of the 307s or 206 CC Wheels, these two wheels are also visually satisfying in 206. I say the spring is 3.5 cm but don't expect too much. As soon as I say it is for comfort, it is up to the use of the spring subject itself and its usage style, after all, it will be 5 cm and 3.5 cm, you can adjust the rubber sidewalls. The backs are already torn.1 or 2 teeth will be enough.
08.05.2020 17:45 # 5
otosundur
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-jant-lastik-takimlari-indirim-206-rc-orjinal-fransiz-peugeot-jant-lastik-195- 45-16-124541596 / detail /
08.05.2020 17:45 # 6
yetkin
15 '' RC Wheel Original
