Friends help :(
08.05.2020 18:18 # 1
I have 207 trendy owners at 3800 km.
In 4th gear there is a hum that starts at 50 km speed, especially 2000 rpm and below.
especially 2000 cycles and below ... 5. doing it in gear.
As the speed and speed increase, the sound does not increase, but it disappears.
I added a video.
I would be glad if you watch and give information. are you like this?
note: transmission oil is not missing by the way ... 3 months ago, a total of 75w80 oil was put into service. 2 liters ...
[TUBE] http://youtu.be/2ıvxv7uo5dy [/ TUBE]
08.05.2020 18:18 # 2
herry
Isn't 50 km of speed in 4th gear low? I don't throw 70 out of 70, but the engine feels the gear it wants.
08.05.2020 18:18 # 3
As I mentioned above, the problem is already doing 50 km and around, which is a low speed in 4th gear.
For example, you do not hear this sound in normal use, ie when you change gears in the 2500-3000 rpm range.
Especially 50 km and around in 4th gear. If you have noticed, I tried to use it in the video at 2000 rpm and below, so that it can be heard more comfortably.
maverick 2014-02-20 19:11:47
08.05.2020 18:18 # 4
herry
Yes, I understand, I did not know, did he sound because he wanted a lower gear? at least it seemed to me. I hope it is not that it will cause trouble.
08.05.2020 18:18 # 5
Turgay_66
I think it is not right to go with 50 in 4th gear, I do not even find the tachometer of 2000, the vehicle is having a hard time to accelerate in high gear, so I think it is coming so there is no problem in your vehicle you can ride it easily :) Turgay_66 2014-02-20 22:25:37
08.05.2020 18:18 # 6
[QUOTE = Turgay_66] I think it is not right to go with 50 in 4th gear, even if the revolutions do not reach 2000i, the vehicle is having a hard time to accelerate in high gear so I think it is coming so there is no problem in your vehicle you can ride it easily :) [/ QUOTE ]
I know friends, the 4th gear's value is not 50 km. But one day the traffic stuck in front of me, the speed fell to 50 km and the revolution fell to 2000. I did not lower the gear. then I realized this event.
especially in the revs 1750-2000, the gear is at 4, while the speed is 50. otherwise the value of the 4th gear is between 80-100 km.
08.05.2020 18:18 # 7
206+bulent
it just seemed like the wrong gear selection to me fearles 2014-02-21 12:58:22
08.05.2020 18:18 # 8
eguet
Everyone has already quit 50km of the gear, not 4, because the engine is stuck, what does it bother if it does not do when it is used in normal gears? after all, the car has no problem Thumbs Up
eguet 2014-02-21 13:36:31
08.05.2020 18:18 # 9
volkanC2
The master is not a quarter tank of petrol left :( :)
08.05.2020 18:18 # 10
We cannot fulle after the gasoline hike.
08.05.2020 18:18 # 11
[QUOTE = maverick] We can't ful after gasoline hike. Even 40 pounds of needle can't be traced. [/ QUOTE]
Hi;
Did you try or drive in normal driving?
08.05.2020 18:18 # 12
[QUOTE = dogan106] [QUOTE = maverick] We are unable to fulle after the gasoline hike. Even the 40 pound hand cannot be traced. [/ QUOTE]
Hi;
Everything seems to be normal when I switch gears 3000dd, which is economical driving.
I did not feel a hum in the video when I drove in these times.
Of course, I know it is too low for the 4th gear, but I realized that when I did not downshift in the traffic stuck one day. otherwise, I'm trying to change 3000 dd gear.
maverick 2014-02-21 20:24:00
08.05.2020 18:18 # 13
ahmed206
Relax, it's not a thing. Not much can be heard though, but I think it looks like the hum in every vehicle.
