Friends Gas gauge problem?
08.05.2020 14:13 # 1
Friends I just signed up I need your help. When I go on the gas with my 307 Xr vehicle, both the gas indicator and the gas gauge are falling. What could be the reason?
08.05.2020 14:13 # 2
C!N
If I think that the chronic problem in LPG peugeot was becoming normal thanks to an extra part, it is not something to be done too much, it seems to be happening in my vehicle.
08.05.2020 14:13 # 3
You better still solve this problem
08.05.2020 14:13 # 4
C!N
The last price I remembered was 130 TL.
08.05.2020 14:13 # 5
fatih1903
not necessary !!!
08.05.2020 14:13 # 6
He has no problem but a psychological discomfort. If you are disturbed by the eukes, they will wear that role and your problem will be solved
08.05.2020 14:13 # 7
H-a-d-i
the gasoline needle drops as the wheel rotates. that's all. this is not a problem. As it is said, it only gives psychological discomfort.
this topic has been opened twice before. you can also take advantage of it.
08.05.2020 14:13 # 8
I have the same situation in me. When the tank indicator turns red, depolation system displays fault message and the engine light is on.
08.05.2020 14:13 # 9
fiddle
I have the same problem ... so how do we actually know how much gas is left?
08.05.2020 14:13 # 10
BuRCaK
this piece is 130 TL. I asked places that wear LPG, but none. That's why I can't get LPG. If I find a place with the part, I will have it there.
08.05.2020 14:13 # 11
can32
friends are wearing that service in ankara.
but I think it is not necessary. In the new generation peugeot, the gasoline needle drops according to the trip computer. If you go in the tube, road information. the needle falls because it works. The inserted part resets the float at each contact opening and gets the correct value. The needle shows again the correct value if enough gasoline is taken or the ignition is not opened for about 18 hours before this part is installed. But if you say it bothers me, it was 140 TL, which I remember in the last time.
08.05.2020 14:13 # 12
muhlisoz
Does anyone have any idea about the name of the track?
08.05.2020 14:13 # 13
bodrum7
My friends vehicle is scuba, there was a line of gas from a half tank in the vicinity, 20 days ago, because of the constant fuel low warning these days, I bought 5 TL gasoline first, but the gasoline needle did not rise immediately, then I bought another 10 TL gasoline, but there was still no movement in the needle. When I start the car, it gives fuel low warning. In 20-25 days, could a car with LPG decrease so much, or did the car not detect that gasoline was taken? Because when I bought 10 liters of gasoline, the gasoline needle was coming to its normal place.
