Friends doors don't open
08.05.2020 21:10 # 1
lilokan
The door is locked and the doors are not opened. How will I open this door in the body shop?
08.05.2020 21:10 # 2
whisky
if it does not open from the control and the door handle. the control battery may be running low. The bsi may be wet / damp so it does not detect. You can disassemble the battery heads and install it after 3-4 minutes and try again from the remote control. You can try to use it by cleaning the door handle can be filled with dirt dust mud. These are the things that come to my mind.
08.05.2020 21:10 # 3
pusutr
The body shop cannot open the course, but the qualified keymaker can easily open the job.
08.05.2020 21:10 # 4
First of all, take a wd40 style spray lubricant, press the key hole, wait 10-15 minutes and try it. If it still doesn't open, a good auto keymaker will open it as our friend says.
08.05.2020 21:10 # 5
lilokan
[QUOTE = whiskey] does not open from the control and door handle. the control battery may be running low. The bsi may be wet / damp so it does not detect. You can disassemble the battery heads and install it after 3-4 minutes and try again from the remote control. You can try to use it by cleaning the door handle can be filled with dirt dust mud. These are the things that come to my mind.
Sir, we can't open the hood because the doors are not urgent. Imoblayxan suphelen I'm
08.05.2020 21:10 # 6
lilokan
Sir, we cannot open the hood since we cannot open the doors. (
08.05.2020 21:10 # 7
lilokan
[QUOTE = sonerkyl] first take a wd40 style spray lubricant press into the key hole, wait 10-15 minutes and try it. If it still doesn't open, a good auto keymaker will open it as our friend says. I have cracks on my ten windows. on care on cami kiricam yarin
08.05.2020 21:10 # 8
If you are in Ankara, it does not take 10-15 minutes for auto keyers to open the doors. If it is as you said, there is no other option than to break the glass. Did you change the battery and experimented and send a control signal to the vehicle. There is a device in auto keyers, they are looking immediately. & nbsp;
08.05.2020 21:10 # 9
lilokan
[QUOTE = sonerkyl] It doesn't take 10-15 minutes if you are in Ankara. If it is as you said, there is no other option than to break the glass. Did you change the battery and try it out and send a control signal to the vehicle? There are devices in auto keyers. They look right away. & nbsp; [/ QUOTE]
Battery replacement teacher. Unfortunately, this is the district where we can have the signal checked.
08.05.2020 21:10 # 10
hmm, that bad teacher will break the glass.
08.05.2020 21:10 # 11
lilokan
[QUOTE = sonerkyl] hmm, that bad teacher will break the glass, you have to be past. The control is directly activated, it locks and hurts. I was wondering if there was an immobilizer problem or something
08.05.2020 21:10 # 12
OguzhanKucuk61
[QUOTE = lilokan] [QUOTE = sonerkyl] hmm, that bad teacher will break the glass. Obviously. The control is directly activated, it locks and hurts. I was wondering if it was an immobilizer problem or something. The vehicle works by reading the chip while cranking. & Nbsp;
08.05.2020 21:10 # 13
lilokan
[QUOTE = OguzhanKucuk61] [QUOTE = lilokan] [QUOTE = sonerkyl] hmm that bad teacher must break the glass. ACTIA. The control is directly activated, it locks and hurts. I was wondering if it was an immobilizer problem or something. The vehicle works by reading the chip while cranking. & Nbsp;
Sir, what could be the problem? When the door was opened, the control started working instantly.
08.05.2020 21:10 # 14
Then, the control was not receiving a signal, as I said from the vehicle, it is necessary to find a good auto keymaker and look at the signal status. maybe one of the door locks may be short-circuited.
08.05.2020 21:10 # 15
lilokan
[QUOTE = sonerkyl] then the control was not receiving a signal, as I said from the vehicle, you should find a good auto unlocking and look at the signal status. Perhaps one of the door locks may be short-circuited. [/ QUOTE]
Soner I want to change the door lock of your vehicle. It is not only important to get it but different key. The central lock complex does not change, or just my key ring
