Friction Noise When Turned Left
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:05 # 1
savatafatih
Hello, my vehicle is 406. 2000 model. For the past week, there are left turns and generally 2 laps and a friction sound on the move. As if rubbing the wheel into the fender .. Or a little thinner. like a little bit of metal. The tire rubbing sound became a little more realistic. What could it be? Does anyone know? tşk
08.05.2020 15:05 # 2
[QUOTE = savatafatih] Hello, my vehicle is 406. 2000 model. For the past week, there are left turns and generally 2 laps and a friction sound on the move. As if rubbing the wheel into the fender .. Or a little thinner. like a little bit of metal. The tire rubbing sound became a little more realistic. What could it be? Does anyone know? tşk [/ QUOTE]
Most likely cv joint (constant-velocity joint)
This is the part in your vehicle:
This is the place (not your vehicle)
Koliva 2011-02-11 22:30:22
08.05.2020 15:05 # 3
New users are required to introduce themselves. Please take a look at " LET'S KNOW OUR MEMBERS ".
08.05.2020 15:05 # 4
savatafatih
teşkler. sometimes it sounds a little while going normally .. I hope it will not be a problem because of the work I can not go to the service for a while ..
08.05.2020 15:05 # 5
savatafatih
What is the name of this piece in services or industry? Do I understand if I say exactly?
08.05.2020 15:05 # 6
[QUOTE = savatafatih] What is the name of this piece in services or industry? Do I know if I said exactly? [/ QUOTE]
I guess they don't understand. Since I did not know Turkish, I wrote it and put a picture. Someone who knows will come and write.
If there is the same sound on the way straight, this may not be from the track. I gave this answer according to your first message.
08.05.2020 15:05 # 7
ozgun
I also check to see if it turns the wheel all the way to the left and rub it into the hood.
08.05.2020 15:05 # 8
307P
I also check if [QUOTE = original] turns the wheel all the way to the left and rub it in the hood. [/ QUOTE]
I also have a problem with the left wheel, when I break a certain amount to the left or right, I think it hits the hood because it sounds like what can be done?
08.05.2020 15:05 # 9
ozgun
[QUOTE = 307P]
one or more of the screws of the hood may have come loose. Check them out. If you do not notice, go and look at the body shop, throw a nut at the most, you will throw 5 lira. Gülme
08.05.2020 15:05 # 10
semih
I thought the MRBs had the same problem in my car, rubbing against the fender. That sound was caused by the flows.
08.05.2020 15:05 # 11
werty
I have this kind of sound, but I just do it when I go back.
08.05.2020 15:05 # 12
savatafatih
friends checked what you said, but know what happened. Maybe I couldn't explain it fully.
I think the steering wheel and wheel are taken from the same place, hydraulic oil is missing.
He completed the oil master and passed ..
Get your news ..
08.05.2020 15:05 # 13
dbmaster
leave it on the road, don’t hit the gas at the turns, the axle head is cracked, you should handle it as soon as possible
08.05.2020 15:05 # 14
metin
I want to ask a question when I have found friends who understand the ready front team.
I changed the triger of my vehicle. The so-called master, the personal trigger, removed the right tire and hood and changed it from there.
After that day, while passing through the bumps on the road, the voice of "garç-gurç" started to come up and descend from the front to the front, and I could not find a solution.
Not always, he does it in large bumps when the vehicle is too flexible.
I will be glad if you help.
08.05.2020 15:05 # 15
[QUOTE = text] I want to ask a question when I find friends who understand the ready front team.
I need to see it. But if you can still, put your car in the canal to see the gold. Then flex the parts under the vehicle with your hand one by one and move them. If you can catch the same sound, it's the problematic track. Does it sound from one side?
08.05.2020 15:05 # 16
metin
koliva first of all thank you for your interest.
the sound comes from the right side. a subtle voice. I don't know exactly, but it seems like something is rubbing on the hood.
respects.
08.05.2020 15:05 # 17
onedin
Look at the oil of the steering wheel, which came to my press. The steering box was greasing. Especially when it was left right or right left, it felt like a knock.
