Friction from the heater
21.02.2021 20:58 # 1
berate38
First of all, good evenings, I was a passive follower of the issues. After selling the 206 and buying the 207, I took it to the industry to have the vehicle serviced. One of the ignorant master said that after removing the ğolen filter, clean the fan on the open, I turned the fan on, the friction sound is not heard at 1, but the sound of rubbing is excessive in all levels. I'm depressed, please help, thank you in advance.
22.02.2021 00:48 # 2
muzzy35
I did not understand what was going to be cleaned after I took the filter out, but my uncle had come to his head before, a thin branch came out of it, and it was just stuck on the propeller. Probably the leaves etc. have escaped when you run without a filter
Get well, I hope it is nothing else
22.02.2021 07:37 # 3
berate38
Well, did you disassemble the fan or did the mechanic disassemble it? How can we remove the chest? Do I need to remove the chest? My hand is susceptible to these works. If described, I will remove the fan myself.
22.02.2021 16:23 # 4
muzzy35
No, the gas pedal pulled a plastic from there and saw it, but if you want to search for it on the internet, maybe you can handle it.
22.02.2021 22:49 # 5
berate38
Thank you for your help, I decided not to handle it. Every time I get into the car, the truck will drive crazy, even if I get a master to handle it, let it clean the inside of it and put it back, otherwise he will sell the car to me. Smile
23.02.2021 08:41 # 6
muzzy35
It makes the most sense :)
