frequent bulb replacement
08.05.2020 21:27 # 1
Bayer
Hello friends.
In my 12 years old 207 car, especially the dipped beam headlights often need to be broken and replaced with a new one. It is not in my mind how much it has changed, what is normal, how long does it last for bulbs? Could there be an electronic problem in the vehicle?
08.05.2020 21:27 # 2
kaan206
I used original bulbs for 13 years at 206m old, never changed kaan206 2020-02-12 18:54:09
08.05.2020 21:27 # 3
muratd
I may not be able to diagnose exactly, but I can make an average estimate by saying that there may be a connector malfunction due to high charging of the charger. For example, is the headlights dimmed when you press the glass opening button, or when it travels, does it dim and multiply like a selector?
08.05.2020 21:27 # 4
talip206
When attaching, do not touch the glass part with your hand. It bursts easier when the finger touches.
Apart from that, starting with the headlights on will cause easy explosions.
If the charger is charging irregularly, it may explode.
