Forget 307cc headlights on
08.05.2020 21:18 # 1
atommbk
Good day car 2005 model 307cc 2 days ago I parked the car at 12 o'clock at night, after 48 hours, I saw the headlight light in the car park tonight, when I went to the car, I looked at our vehicle. When unlocked and entered, the headlight arm was open. I closed the ignition, I opened the ignition, I saw the text "economy mode ..." I don't understand, can parks last 48 hours? How did the battery not run out? And it is impossible not to notice the warning signal when getting out of the car at night.
08.05.2020 21:18 # 2
the problem is probably your headlight signal tower has trouble. The battery did not burn for 48 hours and the battery would be exhausted. In addition, something was added to the car afterwards, like the sound system - exnon.
08.05.2020 21:18 # 3
atommbk
There is a sound system in the vehicle. But I don't know how you can open the headlight arm.
08.05.2020 21:18 # 4
unfortunately the airbag steering wheel must be removed to open it. you need to be a little bit careful. You can find youtube video if it says headlight switch lever change.
08.05.2020 21:18 # 5
atommbk
Thank you. The airbag light is on and on?
