For 206, 3 line display help please ...
08.05.2020 16:43 # 1
gngburak
greetings friends!
& nbsp;
I bought a 3-line display for 206, it was all normal, but today I realized that the left back door does not give any warning when the other doors are normal.
was normal when I first installed. anybody have an idea.
08.05.2020 16:43 # 2
gngburak
I wonder if anyone knows
08.05.2020 16:43 # 3
ibrahim YILDIZAK
There may be a problem with the socket or there may be a problem with the door sensor.
08.05.2020 16:43 # 4
ufuk91
Let me ask without opening an extra subject, friends, what kind of features can this 3-line display add if the car is not ex-factory and installed later? or is it adding something? I have 2000 roland garros in the original, there is no trip computer or something, there are 2 lines of screens, what changes do I mean, what would be the return?
<= "text /" = "" = "/ B1D671CF-E532 -4481-99A to-19f420d90332etdefend is / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0 ">
08.05.2020 16:43 # 5
gngburak
I unplugged the socket, plugged it back in, but in vain
I don't know which sensor is, let me tamper ...... let me see ...
08.05.2020 16:43 # 6
gngburak
I swear I don't know exactly, horizon brother
08.05.2020 16:43 # 7
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = gngburak] I do not know exactly horizon brother
Your car was normally broken in 3 lines, or you changed it from it, bro, or are you using 3 lines of screen for the first time?
Jove! I did not know your problem, but if there is no problem with the device connection, there is a contact etc. in the connections on the door, maybe & nbsp; "Ouch"
08.05.2020 16:43 # 8
gngburak
I had only one line, I don't know much about it.
I saw here, I bought the name as a 3-line display, I took it myself. but I do not know what those numbers mean
someday I will take a picture and sting a subject here > I disassembled the screen, the problem still continues.
08.05.2020 16:43 # 9
gngburak
I wonder if there is a back door sensor but I do not understand
08.05.2020 16:43 # 10
Alicilik
horizon,
3 lines display More efficient for 206s after 2002. The trip computer key is created with the change or modification of the wiper arm, and then you activate and use it with the pp2000.
The pluses I see are:
- Road computer (the road that can be driven with the current fuel, the road since the reset, instant fuel consumption, average fuel consumption since reset, average speed since reset - You can reset this information by holding down the wiper key.)
-You can see the date, time and outside temperature at the same time.
-If you are using the original tape, the view is more pleasant is happening. You can see the recorded channels in the form of a list, sound adjustment etc. is more pleasant.
- You can add a speed warning. Warning appears on the screen when you exceed the speed you set.
- Warnings appear in the form of text.
08.05.2020 16:43 # 11
ufuk91
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0"> [QUOTE = ScHerZo] horizon,
< br> 3 lines display works more efficiently for 206s after 2002. The trip computer key is created with the change or modification of the wiper arm, and then you activate and use it with the pp2000.
- You can add a speed warning. Warning appears on the screen when it exceeds the speed you set.
-Warnings are displayed as text. it is? let me know, for example, as the friend says, the doors are open warning etc. these are not normally there, how such a feature can only be added with the screen, I could not understand it, so I do not understand from these works so see excuse & nbsp;
08.05.2020 16:43 # 12
qqyyxx
[QUOTE = gngburak] friends greetings!
& nbsp;. If you have an idea.
the problem is caused by the door sensor or the cable. If it is related to the sensor in the door, it may be from the road computer but it is probably the door sensor or cable.
08.05.2020 16:43 # 13
gngburak
Thank you very much.
08.05.2020 16:43 # 14
gngburak
& nbsp; I will ask you something, brother, where did the door sensor look, but I don't understand. gngburak 2012-04-27 23:48:51
08.05.2020 16:43 # 15
qqyyxx
it needs to be inside the door lock assembly. It is different for the front doors, between the fender pillar and the door.
08.05.2020 16:43 # 16
qqyyxx
-Warnings are displayed in the form of text. Can be active when the stabilizer is attached. Or can it be set on the current system.
08.05.2020 16:43 # 17
Ozgur
no speed warning anymore. first time heard. Free 2012-04-28 12:05:18
08.05.2020 16:43 # 18
gngburak
I looked like you said ewet when I opened the back left door, the ceiling lamp does not light up.
& nbsp;
now you can describe which sensor. I wonder if I can solve the problem
08.05.2020 16:43 # 19
ahmed206
[QUOTE = gngburak] I looked like you said ewet when I opened the rear left door, the ceiling lamp is not on.
& nbsp;
[/ QUOTE] I am releasing this issue with your permission. Where is the sensor?
08.05.2020 16:43 # 20
C@GL@R
It is not related with the subject, but where did you find the screen and how much you got it. I did not work as soon as I plug it in or did you activate it from the dealer ... I made the button.
Page : / 2
