For 16 inch 206 instead of 14
08.05.2020 20:23 # 1
emreerguner
Original problem 175/65/14 1.4hdi 206 or 195/45/16 what is the problem, what are the pros and cons
08.05.2020 20:23 # 2
comfort falls considerably. undercarriage is often broken. fuel increases a little Smile
08.05.2020 20:23 # 3
emreerguner
Now it is 185/55/15 plugged according to what kind of difference it will be in the fuel. It burns around 23 krş. If it is 25-26krş, it is not very important.
08.05.2020 20:23 # 4
I guess it would be around 25-30. As the rubber sidewalls become thinner, the rubber will not be able to absorb the sling in obstacles such as bumps, that is, the suspension will become stiff and the stretch is reduced. The already weak undercarriage z-rot - tie rod end - tie rod - lower table (swing) - runoffs etc. You will often need to go to the rot - balance setting, which will wear out more quickly.
08.05.2020 20:23 # 5
CemDemiral
[QUOTE = sonerkyl] comfort drops a lot. undercarriage is often broken. fuel increases a little Smile [/ QUOTE]
I agree with Soner evening dresses 15 would be a little more comfortable 16 or huh if you say visually important to me, if you say I'm not disturbed while passing through the pits, of course: D
08.05.2020 20:23 # 6
Popomundo
I think it will tire the 16 cars, search adventure Smile
08.05.2020 20:23 # 7
onlycihan
neither the flesh of the car nor the leg of my car 185/55/15 there is not even a little comfort.
08.05.2020 20:23 # 8
Oktkor
If comfort is not a problem, make it 19 inches directly on the rims, but it looks very stylish. :)
08.05.2020 20:23 # 9
maximusti
I would turn from 14 to 16,
there was a slight increase in fuel,
handling has increased a lot.
but you even feel you fly over the fly on the road.
comfort fell quite a lot.
08.05.2020 20:23 # 10
aykutbayram1996
The same rim also has 206, I don't have to worry about it, you feel a bit too bad on the road.
08.05.2020 20:23 # 11
emreerguner
Thank you all for your comments
