Follow Me Parking with the Ceiling Lamp - Image Appendix
08.05.2020 17:44 # 1
tlp
I will tell you a very simple but functional and fun application.
Connecting parking lamps to the ceiling lamp and as a result Follow me Park construction :)
1 stage
I pulled the cable from the ceiling lamp to the parking lamp, I insulated the cable beautifully from the wicks
Stage 2
I checked the electric cables coming to the ceiling lamp one by one. There are 3 separate cables going to the ceiling lamp.
1 chassis
1 fixed + (connected to the ceiling light button)
1 from the doors, that is, triggered when the doors are opened +
The cable that we will use here will be + coming from the doors, the purpose is to burn the parks when the doors are opened or the central lock is activated.
It was not that difficult to detect this cable because it has a thinner structure than other cables.
I gently tied one end of the cable I pulled to this thin cable
Phase 3
I connected 2 more cables to the end of the cable I pulled to the parks. The reason I asked when I asked one person before doing the application was, "The brain was looking at the cables going to the parks separately, and when any of them had a malfunction, it was appropriate to pull 2 cables."
After pulling 2 cables, one right and one left park, it was the most important part.
Stage 4
It is necessary to connect diodes between the parks and the ceiling lamp. The reason is to prevent the ceiling lamp from burning when the parks are opened.
I did this using a 6A diode
The feature of the diode is for friends who do not know, "to summarize a circuit that does not transmit electricity from one side to the other."
This is our diode. The gray striped part of this diode does not conduct electricity to the other side.
This is how we make our connection
In other words, we connect the gray striped part to the + end of the parking cable and the other part to the cable end we pull from the ceiling lamp.
Thus, when the ceiling lamp is on (Attention !! The parks do not light, even if it is opened manually because the connection is made to the cable triggered by the doors), the parks are lit.When the parks are lit, the ceiling lamp does not illuminate because there is no electricity to the ceiling lamp.
It's not hard work, I had a lot of fun doing it.
It is invaluable to watch especially when my work is finished :)
When this feature turns on and off with the remote control, this feature lights up the parks because it lights up in the ceiling lamp.
On the other hand, it is a good application in terms of security ..
As the ceiling lamp flashes slowly during the central lock, a nice pattern emerges, especially with the LED park-stop or angel rings.
The cost of this application is as follows
2 pieces 6A diode: 2 TL
10 mt cable (I bought extra): 5 TL
Schema
http://www.resimagaci.com/img/trdb527.jpg
http://www.resimagaci.com/img/t4dldj.jpg
I could not take a picture during the application, but the video is below
[TUBE] Z5 is-7_qkzzw [/ TUBE]
Photos
Ceiling light cable entries like this
We draw a parallel cable from the thin one
After separating the cable you pulled from the ceiling lamp to right and left parking areas, we connect diodes for each side. The gray side of the diode will be connected to the cable leading to the park, the black (the other) side will be connected to the cable coming from the ceiling.
After connecting, insulate thoroughly. Rotate 5-10 layers of tape
tLp 2013-07-09 12:41:53
08.05.2020 17:44 # 2
Alicilik
I know the jobs you have demanded from the very beginning. Health to your hands. I had projects for 206+, I brought the materials to fln, but auris broke the works, now I am trying to fix the material I will come with a very sweet application ...
08.05.2020 17:44 # 3
FTH
stable
08.05.2020 17:44 # 4
candanxyz
Congratulations..
08.05.2020 17:44 # 5
Serkan
Talip, who has been number 10, has
08.05.2020 17:44 # 6
rolandgarros
health to your hands Clap
08.05.2020 17:44 # 7
error
congratulations good idea Clap But you have to warn your friends who are thinking about the application. Shocked
08.05.2020 17:44 # 8
ufuk91
As soon as I find time, I will implement it very successfully. Thumbs Up
In the meantime, I will ask you, for example, in the car in the video, the parks + front signals are connected to the parks, I want the front signals to open with the parks. What kind of an application should I do for this? Also, the constant burning of the front signals is not a problem in traffic, is it?
08.05.2020 17:44 # 9
blinddark
so where did you connect this park where did you handle my fuse box
08.05.2020 17:44 # 10
FTH
The same application happened in my car, I got the American park hooked up like the video :)
08.05.2020 17:44 # 11
tlp
[QUOTE = ufuk91]
In the meantime, I will ask you, for example, in the car in the video, the parks + front signals are connected to the parks, I want the front signals to open with the parks. What kind of an application should I do for this? Also, the constant burning of the front signals is not a problem in traffic, is it? [/ QUOTE]
American parking module is on the market
combining intentional parks and signals to light the same bulb
Since the doors are opened, when they burn in the quadrants, they are burning both as a park and a signal with the carpet :)
In the meantime, do not connect at the park lamp outside, as your friend said.
Since the parks and ceiling lamp voltage are the same, there is no problem
You can do other types of heavy damage. For this, additional modules are sold in the market (such as short or long).
I am not responsible for any possible damage :)
I have been using this application for 1 year no matter where you look.
If you have questions, I answer in detail
08.05.2020 17:44 # 12
ufuk91
Okay, let me just say a second, then, what we call parking lamps is in the corners of the headlights, right? Along with them, the signals next to the vehicle are also on fire. But the fronts are not burning. So is there an American parking module in my car now? It was like this when I received it. I know I always read it as an American park but when the side signals are not blinked in front of me, I am confused
08.05.2020 17:44 # 13
tlp
[QUOTE = ufuk91] Okay, let me just say a second, then, what we call parking lamps is not in the corners of the headlights, is it? Along with them, the signals next to the vehicle are also on fire. But the fronts are not burning. So is there an American parking module in my car now? It was like this when I received it. I know I always read it as an American park, but I was confused when the side signals were not blinked in front of me [/ QUOTE]
Parking lamps outside the headlights, yes!
There are 2 options
They make the side signals in the cross connection. If I don't remember the wrong, they remove the minus cable from the signal in the fender and connect the park.
As I said, when I turn on the signals, the signals in the fender are reversed in comparison to the normal signals.
Another option is the American park.
08.05.2020 17:44 # 14
ufuk91
[QUOTE = tlp] [QUOTE = ufuk91] Okay, let me just say a second, then, what we call parking lights is not in the corners of the headlights? Along with them, the signals next to the vehicle are also on fire. But the fronts are not burning. So is there an American parking module in my car now? It was like this when I received it. I know I always read it as an American park, but I was confused when the side signals were not blinked in front of me [/ QUOTE]
There are 2 options
Another option is the American park [/ QUOTE]
It was exactly as you said when I first bought it, that is, it was burning upside down. However, I had an accident 2 weeks ago, went to the service, the car I bought 4 days ago, they took care of the reverse combustion. I did not say that you could do it, but they probably thought that they had made a mistake and put it in order. I think I think there is no american park then?
08.05.2020 17:44 # 15
tlp
Service is generally origina
The same had happened to me
It can be so
There is an American park module, but the fender signals may not be burning.
The reason for this is the installation from the field that differentiates the fender signals.
You can do the fender test by pulling a parallel cable from the normal beam signal.
Besides, the fender signal will be independent according to the signal, not independent of the signal.
Thus, its signal will burn normally, but the park will burn, and the mudguards will burn because the signal will burn from there.
08.05.2020 17:44 # 16
emre_akdag
Bravo Thumbs Up
08.05.2020 17:44 # 17
Aziz
Everybody is Muslim Ouch
good health to your hand :)
08.05.2020 17:44 # 18
moschino
[QUOTE = blinddark] so where did you make this parking connection where did you handle my fuse box [/ QUOTE]
There are angels in my +206 which cable will we connect?
08.05.2020 17:44 # 19
fatihgg
ClapClapClapClapClap do not really work ten numbers, when i come to istanbul i am in the first place :) health to your hands ..
08.05.2020 17:44 # 20
ErolSs
My teacher was stupid, it was very logical that I thought that the system does not control day and night, it turns on the headlight during the day.
Page : / 6
