follow me home
08.05.2020 19:39 # 1
cimariva
My vehicle is 307 2007 model. I turned off the ignition and made a selector.
08.05.2020 19:39 # 2
barishrocker
Are there any adjustments on the tape? For example, I opened a setting from the tape; My headlights stay on for a while after the ignition is turned off.
08.05.2020 19:39 # 3
ibrahim01
The follow me feature is activated after the ignition is turned off. You can also adjust the setting from the original radio. There is no follow me status when you press the control while getting in the vehicle. because this feature serves to illuminate your way until you get out of the car and get home
08.05.2020 19:39 # 4
cimariva
it just happened once but i did it at noon. Didn't I have to do the same process every time it was not evening or is it enough to be active once?
08.05.2020 19:39 # 5
ibrahim01
you need to adjust it from the car's original radio to be constantly active. once set, it stays on after the stop for the time you set
08.05.2020 19:39 # 6
ggitaristt
The headlights do not light automatically when the car is not running.
When the ignition is switched off, it remains on for the seconds you set.
Do not expect any other than this ..: D
08.05.2020 19:39 # 7
gokhanyalcinkaya
If I have spoken, let me ask, how do I activate this stuff? :)
08.05.2020 19:39 # 8
cimariva
It would be nice if you say how I will be active.
08.05.2020 19:39 # 9
ibrahim01
If you are using the original radio, you can activate it by pressing the menu button and adjusting the burning time after turning off the contact from the user preferences.
08.05.2020 19:39 # 10
ibrahim01
http://tr.aliexpress.com/item/peugeot-307-407-408-c5-screen-for-d45-phone-book-and-song-name-usb-bluetooth-and/32344503302.html
The middle section on the bottom screen is for such preferences.
08.05.2020 19:39 # 11
cimariva
not active I have to make a selector each time
08.05.2020 19:39 # 12
ggitaristt
[QUOTE = cimariva] is inactive every time I have to make a selector [/ QUOTE]
Are you still wondering how?
08.05.2020 19:39 # 13
pepecura
without making selectors each time
follow me home
The rumbling?
no original tape
pepecur to 2016-12-01 12:16:28
08.05.2020 19:39 # 14
SCREAMN
As far as I know, follow me home is not automatically activated in every car landing. If you want to use this feature every time you want to make a selector, I do not think that the factory will put a setting that will be constantly active since the purpose of this feature is to illuminate the way to go home during the day.
08.05.2020 19:39 # 15
pepecura
[QUOTE = SCREAMN] As far as I know, follow me home is not automatically activated in every car landing. If you want to use this feature every time you want to make a selector, I do not think that the factory will put a setting that will always be active since the purpose of this feature is to illuminate the way to go home. [ / quote]
thank you
