FOG LIGHTS ?
08.05.2020 20:18 # 1
CemDemiral
Hello friends, I show the front bumper of my 207 vehicle and the shape of the fog I want to make in the visuals. Do they install fog in the bumper like this one below or do I have to know if I need to change the bumper?
08.05.2020 20:18 # 2
maximusti
you have to change the bumper to be something original.
but it can also be made on the existing bumper. if you find a good master.
In other alternative outlets, you can find a boiler with a bounce sisfar.
08.05.2020 20:18 # 3
CemDemiral
I do not want to change the bumper of the car and do not change the original.
08.05.2020 20:18 # 4
GokhaN
you need to change the bumper, otherwise it will pass the liner.
08.05.2020 20:18 # 5
CemDemiral
[QUOTE = GökhaN] you have to change the bumper, otherwise it will pass the lining, if you don't find a break when you change the bumper, at least 1000 TL [/ QUOTE]
Cry Here's a demoralizing event :)
08.05.2020 20:18 # 6
GokhaN
[QUOTE = CemDemiral] [QUOTE = GökhaN] you have to change the bumper, otherwise it will pass the lining, if you don't find a break when you change the bumper, at least 1000 TL [/ QUOTE]
yes unfortunately but the only common point in the two bumpers is the same logo Smile even if the bidet is out I think it is better not to engage in paint in order to fix the color of the vehicle.
08.05.2020 20:18 # 7
maximusti
That's why I'm not trying at all :)
08.05.2020 20:18 # 8
BLACK LION
If you were in Kahramanmaraş, I would definitely have it built. What we have done here is just what my master friend who is dealing with these works will not have a garage for. Sir, the place at the end of the shutter will be drilled for fog. All kinds of 207 or 307 fog are buried there. Just find a solid master. Fit 206 fog directly to the edges, which does not fit well.
08.05.2020 20:18 # 9
maximusti
[QUOTE = BLACK LION] If you were in Kahramanmaraş, I would definitely have it done. What we have done here is just what my master friend who is dealing with these works will not have a garage for. Sir, the place at the end of the shutter will be drilled for fog. All kinds of 207 or 307 fog are buried there. Just find a solid master. Fit 206 fog directly to the edges, which does not fit well.
I will come to Elbistan this summer, maybe I can come to the center if there is time.
08.05.2020 20:18 # 10
BLACK LION
[QUOTE = maximusti] [QUOTE = BLACK LION] If you were in Kahramanmaraş, I would definitely have it done. What we have done here is just what my master friend who is dealing with these works will not have a garage for. Sir, the place at the end of the shutter will be drilled for fog. All kinds of 207 or 307 fog are buried there. Just find a solid master. Fit 206 fog directly to the edges, which does not fit well.
Thumbs Up
08.05.2020 20:18 # 11
BLACK LION
I try to help. Thumbs Up
08.05.2020 20:18 # 12
hasimayaz
Just be careful, cutting the bumper is irreversible. So as the gavurun says "one way proccess" :)
How to install the headlight is up to your taste, but do not forget to use a vacuum socket and corrosion resistant cable + fuse plug that provides protection against water no matter what you wear. Due to their high electricity consumption and location, the fog lights are susceptible to all kinds of threats. Safety first.
hasimayaz 2017-04-15 22:59:21
08.05.2020 20:18 # 13
yldrmcbb
Hello there,
It has been talked about a long time ago, but I can not ask without question :) I think the 2010 model is not equipped with trendy 1.4hdi factory fog lights. There is no such option in the signal arm.
But when we change the arm and insert fog, does it have to be opened with the software?
Thanks in advance
08.05.2020 20:18 # 14
FatihBall
hello my car is the same color next month i think to install rc bumper in my hand if you want to get the foggy bumper will be wasted I can give it at an affordable price no broken crack
08.05.2020 20:18 # 15
[QUOTE = yldrmcbb] Hi,
Thanks in advance [/ QUOTE]
My fog lamp is closed from the brain. Actually, there is on the arm, when the middle moving part on the left arm makes a step, the front fog lights up and in the second the rear fog. Actually it is present on the arm but you can not see the light on the display because it is not active. your arm should be this
08.05.2020 20:18 # 16
yldrmcbb
[QUOTE = FatihBall] hello my car is the same color next month I am thinking of installing rc bumper in my hand, if you want to get foggy bumper wasted, I can give it at an affordable price I don't have a fracture crack [/ QUOTE]
there is a bumper but no fog lights :) thank you anyway.
08.05.2020 20:18 # 17
yldrmcbb
[QUOTE = sonerkyl] [QUOTE = yldrmcbb] Hi,
I thought if it would be the only tier for me for that reason.
my buffer this way. https://www.google.com/search?q=peugeot+207+2010+1.4+trendy&tbm=isch&ved=2ahukewi-ycxojuznahvqwıukhtvdbgıq2-ccegqıabaa&oq=peugeot+207+2010+1.4+trendy&gs_l=img.3...18249.22546. ... 0.0..0.150.2390.0j19 .22904 ...... ....... 0 .... 1..gws-wiz-img 35i39j0i19j0i8i30i19j0i8i30.z597u43aycc & ei = 1057 & Biwa 4mnuxr7zatcalws1upgqbg & bih = = = 1920 & rlz 1c1gceu_trtr883tr883 # imgrc = j8isjx_so76qkm
But as you said, I would activate the BSI from the brain and buy fog lights and solve this job. Thank you very much for the information.
08.05.2020 20:18 # 18
Yours is a safe case, just enough to buy fog lights. If there is 2 arrows on the arm or if the single stage event is just one step forward, the first stage happens, then when you do the second stage, the second stage allows you to come back, not like the headlight burns. You have to look at it, even fog lights can be ready in your vehicle.
08.05.2020 20:18 # 19
yldrmcbb
[QUOTE = sonerkyl] yours is a good case, you just need to get a fog light, hodja. If there is 2 arrows on the arm or if the single stage event is just one step forward, the first stage happens, then when you do the second stage, the second stage allows you to come back, not like the headlight burns. You have to look at it, even fog lights can be ready in your vehicle. [/ QUOTE]
As you said, there is only one tap event (ie there is only one arrow). Maybe it will be useful if I will learn about the installation in thesis time and share it here.
