Fog lights
08.05.2020 15:08 # 1
masumserseri
Finally, I was finally able to install the fog light. But as I wanted, it was not original. :(
If you are going to install the ss headlight, it is absolutely necessary to determine the location of the headlight from the inside.
08.05.2020 15:08 # 2
Selim Engin EREN
yeah it was a bit too much on the sidelines but use your spin squeeze a little bit later and you look at it.
08.05.2020 15:08 # 3
masumserseri
the place is complete but something little cut off.
08.05.2020 15:08 # 4
MemoTech
Best wishes.
The picture is not noticeable. I'm sure he won't be able to notice when they see people who don't know.
Has the electrical connection been made?
08.05.2020 15:08 # 5
Muhammet CAKIR
brother, I thought I was peeling, I think you should be careful :( some fog lights are coming small, if you cut it according to the hole, it would be okay, but it wouldn't be a problem. you never get hurt Muhammet ÇAKIR 2011-03-07 20:21:11
08.05.2020 15:08 # 6
MemoTech
[QUOTE = Muhammet ÇAKIR] I think I had a brother, I think you should be careful. There are frames, take them from them, and then you will never get [[QUOTE]]
Brother did you make electrical connections? What was the last situation I knew was the last thing that was not done?
08.05.2020 15:08 # 7
Muhammet CAKIR
[QUOTE = MemoTech] [QUOTE = Muhammet ÇAKIR] my brother, I think I was peeling, I think you should be careful :( some fog headlights are coming small, if you cut it according to that hole, I would have said it would not be a problem, but it is not a problem or fill the places that are filled with such paste. :) or the fog lights have frames, take them from them and then you will never be able to [[QUOTE]
[/ QUOTE] I did it a week after my brother tied up the fog
08.05.2020 15:08 # 8
MemoTech
How was it? So did you insert the key externally, I couldn't follow that intermediate topic? Does the headlight operate from the joystick?
08.05.2020 15:08 # 9
Muhammet CAKIR
I put on a new key picture or something, but I forgot about it, it is pretty good, I thought it was to connect the headlamps to the rear foglamp like this, but I would reconstruct it because it is already connected to the neon and jacquard at the bottom.
08.05.2020 15:08 # 10
MemoTech
I have an intention but some say that the fuse box will change, I want it to be controlled from the headlight joystick, but I could not learn exactly how.
08.05.2020 15:08 # 11
masumserseri
I did not connect the electricity yet, but for a while I will get it done.
muhammet meanwhile, I was not certain in the bumper. I get
08.05.2020 15:08 # 12
Muhammet CAKIR
I understand, my brother, good luck, or I will congratulate you. ")
08.05.2020 15:08 # 13
Muhammet CAKIR
By the way, I think the headlights darken, I think everything is completed :))
08.05.2020 15:08 # 14
masumserseri
I HAVE DECIDED MY LOVE YAV :: D
I even washed it well when I was getting it new, it was okay. I squeezed a medicine, I did not remember its name, but it was clear.
the masumserser 2011-03-07 22:18:25
08.05.2020 15:08 # 15
Muhammet CAKIR
: d pleasures and colors are indisputable brother
