Fog lights
08.05.2020 20:58 # 1
onurrr41
Greetings to all.
Yesterday at noon, I received a phone call from my neighbor saying that the fog lights were on (when the car was parked) and went immediately. Luckily, he couldn't run out of the battery, but my fog lights, which normally light up with dipped beam, started to come on when the engine was off. A week earlier, when the vehicle was running, it would not work even with dipped beam headlights on. Right now I removed one of the poles and I'm waiting for the weekend.
08.05.2020 20:58 # 2
Is there an extra electrical equipment in the vehicle. The first thing I can think of is the possibility of a short circuit in the fuse box, and secondly, the headlight signal arm malfunction. but it causes me to eliminate the second option to give electricity continuously. As if there is oxidation in the fuse box. otherwise he would switch to eco mode and turn off the lamps.
08.05.2020 20:58 # 3
onurrr41
What are your suggestions or ways to follow. I would be glad if you can help my teacher
08.05.2020 20:58 # 4
GokhaN
I think there is a problem with your signal arm set, it's time to change
08.05.2020 20:58 # 5
onurrr41
[QUOTE = GökhaN] I think your signal arm set has a problem it's time to change [/ QUOTE]
I fixed the problem. My engine electrical installation had changed. Since the cable going to the role was thin, it warmed and burned the role. We solved it to 100 TL
