FOG LIGHT IN 307 HEADLAMP
08.05.2020 16:22 # 1
106fb
FRIENDS WHEN I OPEN THE FOG LAMPS OF ENIM 307, THE PARK LAMPS ARE OFF, LIKE THE FOG LAMP.
08.05.2020 16:22 # 2
berk2309
You bought a new vehicle & nbsp; old owner belkı & nbsp; park style is equipped with fog, you need to wear a fog light to use it in the weather: D & nbsp;
08.05.2020 16:22 # 3
106fb
It's been about two months. When I say fog light, I have a higher volt lamp. I can't light it up. the same lamp is on.
08.05.2020 16:22 # 4
berk2309
Now you will turn the tip, not the middle of it, to burn the heat.
08.05.2020 16:22 # 5
106fb
Okay, there is no problem in burning. I see that the fog is burning green on the indicator. When you make it back twice, the back fog is burning.
08.05.2020 16:22 # 6
berk2309
yes, then it may be fitted with a low voltage thing to make the owner of the fog lamp obsolete & nbsp;
08.05.2020 16:22 # 7
106fb
BUT THE SAME LAMP IS ILLUMINATED WHEN I COMPLETE THE NORMAL PARK LAMPS. DOES NOT USE THE FOG LAMP IN THE NORMAL?
08.05.2020 16:22 # 8
106fb
Help friends who have 307?
08.05.2020 16:22 # 9
berk2309
different side of me is that the normal dipped headlights are on & nbsp; When I turn on the heat, I get highlighted: D & nbsp;
08.05.2020 16:22 # 10
106fb
There is nothing that should change when I turn on the fog while the parking light is on. As if the fog is not active
08.05.2020 16:22 # 11
gozem
brother, you can get the best 2 Narva brand H1 bulbs there and it will work smoothly
08.05.2020 16:22 # 12
berk2309
Maybe it comes into play, you do not notice it, it will open to you.
08.05.2020 16:22 # 13
106fb
No, it's not that much anymore.
08.05.2020 16:22 # 14
106fb
it is said that the installation of the fog lamp in a few places is ready but there is no electricity.
08.05.2020 16:22 # 15
gozem
[QUOTE = 106fb] no, it's not that much anymore. > don't worry any more than H1 does not fit anyway :)
08.05.2020 16:22 # 16
106fb
NORMAL IS BURNED IN THE FRIENDS WITH OTHERS 307?
08.05.2020 16:22 # 17
felusdomesticus
I just bought it. The front and rear fog lights also work normally. It's pretty bright.
08.05.2020 16:22 # 18
inceyasar
my car 307 1.4 hdi xr I want to pull the line by triggering from the rear fog, but I couldn't deal with it. The front fog was burning in our cars, unfortunately, there was no control on the arm.
08.05.2020 16:22 # 19
106fb
[QUOTE = felusdomesticus] I just bought it. The front and rear fog lights also work normally. It's pretty bright. [/ QUOTE]
You just bought my car?
08.05.2020 16:22 # 20
berk2309
the vehicle is new, so they say: D electrics don't come, they said to you, my brother, when did they say that my electrician fade & nbsp; I was taken care of the queues & nbsp;
Page : / 3
