fog light adjustment
08.05.2020 19:54 # 1
huseyin.celebi
Hello ,
Although everyone said on Monday, I broke the mists of my 106 quicksilvers, I separated them from the longs. Then my openness went up to the people and I removed the parking lamps. I said I would only travel with the American and fog, but I did not understand much during the day, then I said that I would start the car last night and see how it would be at night. Only the fog is shorter and shorter than the longs, and the lights illuminate upwards, while I went on the road, 1-2 people said that I was disturbed and I did not want to disturb anyone, so now there are 2 issues I would like to consult you.
1. Do I install a led bulb in the system? something like this ----> http://urun.n11.com/led-far/h1-ledli-sis-ampulu13-led1-takim-fiyatidir12v-P113702526
How do I adjust or adjust the 2.106 fog lights facing up to the original point as far as I know?
thanks in advance for your help
respects..
the huseyin.celeb 2016-07-15 12:13:37
08.05.2020 19:54 # 2
You can not get much efficiency from this type of LEDs. In addition, the headlights must have adjustment points above them.
08.05.2020 19:54 # 3
Cyrus35
There is an aluminum bolt behind the fog.
You can adjust the settings in the dark with a flat blade screwdriver.
08.05.2020 19:54 # 4
Gokcesel
I agree with Soner evening dress that you can not provide lighting with the led in the advertisement you provided. I would recommend you either wear a halogen bulb or if you want white, xenon.
08.05.2020 19:54 # 5
huseyin.celebi
Thank you for your answers, I will do what you say and write the results here
08.05.2020 19:54 # 6
huseyin.celebi
Thanks for your help, I made the adjustments from the bolt as you said, thank you very much now I do not disturb anyone, thanks to you
08.05.2020 19:54 # 7
Cyrus35
Thank you, here is a forum for help, we are happy if we could help
