fog lamp
08.05.2020 17:00 # 1
resul0671
friends 307 xt pre. When I bought it in my vehicle, 206 mists were installed but there was no electrical connection.
If I connect in parallel with fog, I would have trouble working. Do you have trouble as a current draw .... a master said that we can burn the fog by connecting resistor ... does anyone know aceba ...
thanks .......
08.05.2020 17:00 # 2
fexzi
There is no problem if you detect the ends of the fog from the headlight and draw a line to the bumper.
08.05.2020 17:00 # 3
Your fuse will blow the most, but even if I knew it wouldn't, I would have fed the extra role + cable if I were. & Nbsp;
08.05.2020 17:00 # 4
fexzi
[QUOTE = koliva] I'll have the most insurance, but even if I knew he wouldn't, I would have fed the extra role with the + cable. & Nbsp; [/ QUOTE]
Direct line is taken from the original headlight inside the headlight, the current is transferred to the sound in the direct bumper In case of trouble, the fuse in the original installation of the fog lamp blows, I write it because I arrange it as you say and make it easy.
08.05.2020 17:00 # 5
simurg
You should get a safe way by connecting the necessary sorts and roles from the aquarium, not from the original headlight line.
08.05.2020 17:00 # 6
resul0671
thanks ..... immediately experience i ....
