Fog Headlight Bulb Explosion
08.05.2020 21:01 # 1
kayaca
First of all Hello,
I have 206 vehicles, led xenon, 30k, I used it for 3 months or so. I changed one more. I used it for 2 more months, then the left side went again. I went, I put on a bulb like lemon yellow, I used it for 1 month, the bulb of the left side exploded again. why does it do that?
I measured the battery, 13.8 v is coming
Doesn't it burn them all if there is a short circuit?
I think it is caused by a light bulb. Why did the LED xenon do it?
Should I buy 8000k led xenon or should I wear water powered ones?
08.05.2020 21:01 # 2
Well, brother, probably because of the poor quality of the products fitted, check the fuse. Balanced bulbs such as xenon damage the electrical installation of the vehicles after a certain period of time. If I were, I would go back to the original.
08.05.2020 21:01 # 3
kayaca
[QUOTE = sonerkyl] Well, my brother is probably checking his fuse due to the poor quality of the products that are installed. Balanced bulbs such as xenon damage the electrical installation of the vehicles after a certain period of time. I would be back to the original or led. [/ QUOTE]
There was a LED xenon, I changed this back 2 times from the motorized ones, both sides did not withstand it.
08.05.2020 21:01 # 4
Selcuk55
There are 2 options, water intake or evaporation too high humidity, or chassis, minus less.
08.05.2020 21:01 # 5
kayaca
[QUOTE = Selçuk55] There are 2 options, it takes in water or evaporation is done from excessive moisture, or the chassis is minus less.
Can it burn if it is minus little but not all go away then? Is it thought that water will make steam, does it take a bit while washing the car or something? But some of the LEDs on the LED xeno are exploding, they're all gone.
08.05.2020 21:01 # 6
Selcuk55
My brother makes blasting due to lack of chassis. In my transit, he was blowing up the headlight bulb on my transit.
