Fog and anarya lamp are not lit!
08.05.2020 20:00 # 1
Peugeot35
Friends anarya (reversing light) in one of the rear stops of the 307 I just bought and the fog lamp did not light in the other. today I disassembled and looked at the anarya lamp (reversing light) had exploded, changed. The fog lamp was intact, but it was not lit even when the two had their lamps intact.
Where is the location of these insurances I mentioned?
08.05.2020 20:00 # 2
My teacher is on the back of one side of the fog, the bulb is spare and the place is placed in the ground. If you want it to burn, you should have the line pulled from the other fog.
08.05.2020 20:00 # 3
Peugeot35
If the fog is spare then the problem remains only in the reversing lamp.
The Reversing Lamp came out and it was writing 12W, it was replaced with a new one. Peugeot35 2016-10-17 13:21:50
08.05.2020 20:00 # 4
You can find the location of the insurance in the link I provided. oxidation in the lamp socket was giving.
http://public.servicebox.peugeot.com/dtt/ddb/
08.05.2020 20:00 # 5
Peugeot35
No, it was clean, it looked like new.
08.05.2020 20:00 # 6
Peugeot35
sonerkyl brothers I found the fuse with the help of the link you provided, the fuse number 1 in the fuse box inside the hood, but the fuse turned out to be solid, my reverse gear lamp is burning one by one very different situation :)
08.05.2020 20:00 # 7
I have to be the only one in reverse gear.
08.05.2020 20:00 # 8
Peugeot35
If the friends with 307 try these two lamps, they will solve the event :) Peugeot35 2016-10-18 13:11:56
08.05.2020 20:00 # 9
xmen
I do not know anarya single lamp teacher without makeup,
08.05.2020 20:00 # 10
Peugeot35
Is there a 307 but also another reversing lamp and rear fog lamp burning alone?
08.05.2020 20:00 # 11
Onur26
I have the 2005 307 sw, the backlight does not light up, we left the only lamp on the right today, the masters change the contactor
they said it needs to be R on the screen but the light is not on
