Fog activation
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
14.06.2020 12:36 # 1
Sarpergur
Good day everyone, my car 2012 active package 208 does not have factory-fitted fog lights, but they have already installed it, but it is not active, where can I activate the sockets are connected, and there is only a rear fog phrase on the fog arm.
15.06.2020 15:39 # 2
Hello, you can do it, teacher. After the fog lamp and frame you need to take is assembled. After activating with original software, the indicators will also light up. It does not light up because it is turned off. Also, if there is an indication for front fog on the arm, you can take a photo, I serve. Unfortunately, I don't know about this in Istanbul.
16.06.2020 10:52 # 3
Sarpergur
My teacher, there is even the sockets of the fog system on my vehicle, but it is not active, there is no front fog sign on the fog arm, but I am looking for a place where I will turn on the front fog lamp with the software available on the speedometer.
16.06.2020 11:52 # 4
If this place is far from you, I will call and say a problem, if you want, many teachers who go from the groups. https://birlikotoservis.com/
27.06.2020 17:19 # 5
betaser
Hello, first you need to install a turn signal lever with front fog light control. Then you need to activate the fogs with the Peugeot Diagbox software. (Front fog light may turn on on the indicator, do not surprise you) There is no relay for fog light in the motor fuse box. You may need to open the inside of the motor fuse box and install a 12V mini relay instead of the empty relay.
01.07.2020 18:56 # 6
Sarpergur
I activated my fog, without the need to change the handle, my master, whom I went to for maintenance, was connected to the obd socket of the vehicle with a computer. Thank you very much.
02.07.2020 10:56 # 7
Thank you. I hope you will be satisfied using it
