Fm Transmitter using Bluetooth?
08.05.2020 20:30 # 1
mburakaslan
I want to use this in my 307 vehicle, I want to use it cleanly without inserting the original tape, but I know that it makes a lot of scratches, normally it is already scratching.
In short, would you recommend this device or will I refresh the tape?
08.05.2020 20:30 # 2
whisky
I bought a double religion, it became a shape and the sound or something improved. I think it's good if the financial situation is good.
08.05.2020 20:30 # 3
maximusti
I tried it in Istanbul, it did not work at all because there is no idle frequency. div> can be used again because most frequencies are empty on the intercity road.
08.05.2020 20:30 # 4
mburakaslan
[QUOTE = whiskey] I bought a double religion, it became a shape, and the sound improved. I think it's good if the financial situation is good. [/ QUOTE]
Make sure I want it too but I guess I won't be able to get double for a long time.
08.05.2020 20:30 # 5
mburakaslan
I tried [QUOTE = maximusti] in Istanbul, it didn't work at all because there is no idle frequency. You can have the same problem in
izmir. If you are going to use
in city, you will need to unplug the antenna of the radio as a solution.
can be used again because most frequencies are intercity on the intercity road. still.
08.05.2020 20:30 # 6
maximusti
[QUOTE = mburakaslan] & nbsp;
My thoughts are connecting to the aux where the cd is installed. If I find how it is done, I will do it directly, but I still can't find it. [/ QUOTE]
If your
confirmation is RD3-01, you can review the following topic.
I used it for a long time before making a
sound system. & Nbsp;
08.05.2020 20:30 # 7
nevce
the only problem I am using is finding the empty frequency, if you set the empty frequency fine, I bought it from the internet for 50 TL and I'm glad you even make a speech
08.05.2020 20:30 # 8
mburakaslan
[QUOTE = maximusti] [QUOTE = mburakaslan]
If I think the aux is connected to the place where the cd is located, if I find how to do it, I will do it directly, but I still can't find it. [/ QUOTE]
If your
confirmation is RD3-01, you can examine the following topic.
sound system.
307 2006 make-up case is different from the tape I looked at. And who does it to whom?
08.05.2020 20:30 # 9
maximusti
[QUOTE = mburakasl of]
307 2006 model make-up case is different from the tape I looked at. And who does this and who should we bring it to? [/ QUOTE]
can you confirm and write the brand model information?
08.05.2020 20:30 # 10
uzunca961
I have done this partly with the bluetooth kit. It allows not only music but also phone calls.
It is usually sold at a price of $ 10. it has both usb and aux input. & nbsp;
Though you didn't have aux input, did you forget? pardon & nbsp;
08.05.2020 20:30 # 11
KEREM KARAMAN
FRIENDS HELLO I WOULD LIKE TO BUY 508 1.6 VTI OR THP AUTOMATIC 2011 2012 MODEL BUT WE HAVE PROVIDED AUTOMATICS DO YOU HELP ME (I HAVE EXPERIENCED THAT I HAVE EXPERIENCED THAT I HAVE EXPERIENCED THAT I HAVE EXPERIENCED THAT I HAVE EXPERIENCED LIKE THAT ARE LIKE THAT ARE I LIKE THE EXPERIENCE)
08.05.2020 20:30 # 12
mburakaslan
307 2006 model make-up case is different from the tape I looked at. And who should we do that to whom we should bring?
Where do I see him?
08.05.2020 20:30 # 13
Furkan979
I bought it, I use it at 307 sw I take the antenna and set 105.0 on the mainland. Seriously, the sizzle almost goes to zero.
